Hey stumbled on this great forum after searching for this topic, but can't find an exact answer for my question (with schematic if possible!). I have been looking at the circuit shown here: A better MOSFET H Bridge Schematic - The Using MOSFETS Website I will be driving two motors from a typical R/C car supplied with 9.6V NiCad (I assume they'll draw about 1 amp). But currently have the following items which differ slightly from those ones (sorry my part numbers might be different as I'm from Australia ) :
From my reading on the theory of H-Bridges these should be fine, as the Rds(ON) is about the same for both MOSFETS (approx .1 Ω), and they're both logic level driven (I hope i read the datasheets correctly). My question is do I need the transistors at all because I have logic level MOSFETS? And can I drive this with two PWM signals as the MCU I'm using (from an autopilot) doesn't have plain digital I/O!! Otherwise I have 8 PWM signals (max) and I can just have them fully on and act like digital outputs, but I'm a little uncertain because I don't think I can fully turn them off (as they're meant to drive servo motors the only settings I have are: min="1000" neutral="1000" max="2000" which are in ms). Hopefully that all made sense, as I'm quite an amateur!!! Thanks for your time. | |
| | #2 | |
They take massively more than 1A, 90A upwards ECS's are commonly used for controlling them. | ||
Sorry I should have worded that better, the 9.6V is the supply to the whole RC (it is just a toy one bought from a toy store), that includes other electronics transmitter/receiver etc. I have driven it off a 1.5Amp micro controller that I used for another project some time ago with no issues.
drwarm (&fuzzy), that diagram is dated 2001. There are much better single chip solutions around today to do the job. Driving P-channel MOSFETS is expensive. You could probably salvage a H bridge IC from an old VCR load/mode select motor drive, if you wanted to experiment. They come as a monolithic solution, where the chip drives the motor directly, no transistors or MOSFETs to add. The attached pdf is an older example IC. Full H bridge driving 4x N-channel MOSFETS. Very easy. sPuDd.. | |
Still had a lot of trouble getting the H-Bridge going, but managed to find some L6203 DMOS H-bridge driver ICs. Just a couple question before I try out the circuit, I'm using pg 11 of this pdf as reference (I won't use the L6506 and just connect micro straight to L6203): http://www.otocoup.com/DocTech/Stepp..._microstep.pdf Do you think a 0.5Ω resistor is ok going from Sense to Ground? Also is there any way to control it with just 2 PWMs per L6203, for instance if I have the two signals also go into an XOR that goes to enable? Thanks for all your help! PS I also know that this circuit doesn't have any dead time, I will try an accomplish this with code. | |
| channel, hbridge, pwm |
| H Bridge Mosfet Fet P channel burned help! | roeebloch | Electronic Projects Design/Ideas/Reviews | 13 | 3rd February 2009 09:44 PM |
| Driving an N channel Mosfet in a H Bridge on higher side | Dummy123 | General Electronics Chat | 6 | 17th March 2008 03:10 AM |
| Using single channel hardware PWM to control H-bridge | ravix | Micro Controllers | 6 | 7th January 2008 04:39 PM |
| designing a h bridge with p and n channel mosfets | ilyaz_mechatronics | Robotics Chat | 2 | 11th January 2005 12:34 PM |
