+ Reply to Thread
Results 1 to 6 of 6
Thread: How to detect a frequency
  1. #1
    MikeBrady Newbie
    Join Date
    May 2009
    Location
    Central Coast, NSW, Australia
    Posts
    20
    Default How to detect a frequency
    I have a reasonable grasp of basic electronics but am struggling to make progress with a 'simple' frequency detection circuit. I hope someone out there can point me in the right direction.
    The basic requirement of this project is to generate an IR light beam with a specific frequency, say 3.5 KHz and be able to detect when this beam is broken.
    Generating the IR beam is not a problem - I've got this working ok using an IR diode driven by a 555 timer chip and a transistor. Where I am getting stuck however, is in how to detect the emitted IR light at the specified frequency.
    I've found some articles on tuned circuits (using inductor, resistor and capacitor) but I haven't been able to figure out how I could use something like this to
    a) detect the presence of the IR light with the 3.5KHz frequency, and
    b) enable a high output when the beam is interrupted
    I know how to generate the input signal (using a IR phototransistor (and a couple of amplifying transistors) - in fact, I can see the received signal on my oscilloscope, but how to measure the frequency, and detect when it is absent is beyond my level of understanding right now.
    Basically, I'm pretty much stumped at the moment and would really appreciate any guidance on what sort of circuit I need to detect this specific frequency
    Ideally, there will be an IC out there that will do pretty much what I need. Even better, would be a circuit that somehow(?) uses the same pulses from the 555 chip to drive the receiver, so that the circuit always stays 'in tune'.
    Any ideas? Your help is much appreciated.
  2. #2
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    If you 'ac' couple an amplifier and configure a low pass/high pass filter that should be OK for an 'interrupted' beam project.
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  3. #3
    JimB Excellent JimB Excellent JimB Excellent JimB Excellent JimB Excellent JimB Excellent
    Join Date
    Sep 2004
    Location
    Peterhead, Scotland
    Posts
    1,947
    To detect the 3.5khz, I suggest that you have a look at the NE567. This is a Tone Decoder, which gives an output when the tone is present.
    Just looking quickly at the datasheet, the output is an open collector transistor which conducts when the tone is present and turns off when the tone is absent.
  4. #4
    suhasm Newbie
    Join Date
    Sep 2008
    Location
    Bangalore
    Posts
    45
    You could get rid of all this and use a TSOP1738 instead. It receives Ir modulated at 39khz only. It is very simple to use and very cheap also.
    You can use "missing pulse detector" circuit to find out when the pulses stop coming. Do a google search for "555 missing pulse detector"
  5. #5
    hog
    hog is offline
    hog Newbie
    Join Date
    Feb 2007
    Posts
    2
    make it simple, go to a tv plunker---they are tuned to 40kc electronic goldmine has both the sender and reciever Lloyd
  6. #6
    MikeBrady Newbie
    Join Date
    May 2009
    Location
    Posts
    20
    Default Online examples of frequency filters needed
    A big thankyou to all for the replies - when I Googled for 'electronics forum' and found this one, it looks like I hit a gold mine!
    I've had a quick read about the TSO1738 and NE567 and can understand how they could be used to solve my problem. However, I think I'll have a play around with a more 'basic/hand-on' solution where I'll try to
    a) filter the signals detected by the IR receiver to isolate just the desired frequency, then
    b) use this as input to a 555 missing pulse detector circuit - the more I learn about the 555, the more I realise what an amazingly flexible component it is.
    Apart from finding a couple of calculators for determining the component values for filtering frequencies I haven't been able to find much else on this subject online.
    If anyone can point me to some good online reading material that will help me to build the 3.5KHz filter from basic components, then that would be appreciated.
    For information, the 2 sites I have found thus far are as follows.
    Guitar Pedals: R-C Filter Calculator
    Tuned Circuit Calculator
+ Reply to Thread
  1. how to detect Ac
    By khatib in forum Micro Controllers
    Latest: 11th March 2009, 04:16 AM
  2. Detect specific squared wave frequency
    By prprog in forum General Electronics Chat
    Latest: 17th January 2009, 03:15 PM
  3. Detect frequency and lock
    By prprog in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th January 2009, 01:16 PM
  4. How do you detect CO2?
    By William At MyBlueRoom in forum General Electronics Chat
    Latest: 23rd June 2006, 07:13 PM
  5. Creating high frequency waves with low frequency crystals
    By loopy in forum Micro Controllers
    Latest: 14th February 2005, 07:58 AM
Tags for this Thread
