Don't connect the bottom end of the 317 to zero volts, connect it to a negative reference instead.
I'm a fairly new student to Electronics and I have to build a variable voltage regulator for my college project. I've got a fairly good idea how to do it using an LM317 but I don't know how to get the LM317 to go below its reference voltage of 1.2v. There is some info on the National Semiconductors datasheet, but when I modelled it on Multisim I couldn't get it to work very effectively. Any thoughts out there?
Thanks Nigel. I did try connecting the adjust leg to -10v on multisim 7 but I still seemed to be getting 0.3v when the pot was fully off. Is it possible that mutisim 7 would be giving me duff info. I'm due to have a crack at building this on Thursday but I'm not confident about it at the moment.
You need a negative voltage.
Here's how it can be done very accurately using an op-amp.
0 to 13.8V LM317 Power Supply
To get 0v from a LM317, put 2 diodes in series on the output.
"Nigels Asm tutorials:" www.winpicprog.co.uk/
"Ian Rogers 'C' conversion of Nigels Asm tutorials:" http://www.electro-tech-online.com/c...torials-c.html
Thanks for helping out with this gentlemen, I'll let you know how I get on!
Cheers
Use an LT3080 which can be adjusted down to zero volts.
Zapper
Curmudgeon Elektroniker
--Inside every little problem is a big problem trying to get out.--
DigiKey have LT 3080 for $3.75 plus $4.95 post = $8.70
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| LM317 and LED | RogerTango | General Electronics Chat | 25 | 11th February 2010, 09:38 PM |
| Lm317 | ylioily | Electronic Projects Design/Ideas/Reviews | 19 | 15th March 2009, 12:08 PM |
| LM317 or 7805 | kalaman | Microcontrollers | 14 | 14th October 2007, 01:12 PM |
| how much does lm317 need? | kalaman | General Electronics Chat | 13 | 27th August 2007, 10:51 PM |
| LM317 | bogdanfirst | Electronic Projects Design/Ideas/Reviews | 2 | 22nd March 2003, 06:59 PM |
