| Hi, I made a metronome to test capacitors. It goes click click, if you have a big capacitor like 10 uf, or it wines if you have something like .01 uf. Anyways, i used it to test the capacitors on a circuit that I made (that doesn't work). Is this a good idea? I compare the sound of two of the same value caps: one that i know is good, and the one that i am testing. Is there any other way to test capacitors w/o buying testing equipment? I'm a little low on funds. Thanx
Another test is leakage, you apply a high voltage and measure the leakage current - obviously the voltage needs to be switchable so you can test different ratings. This was probably more important in the old valve days!. The most common test these days is probably ESR (Effective Series Resistance) on electrolytics, it's a huge problem with modern electrolytics, probably the major cause of faults these days. But your oscillator test is probably fairly useful (and fun!), and fun is what it's all about really!. | ||
| Zach, that is a neat idea! I've never seen someone create an oscillator for that purpose (That doesn't mean that it hasn't been done). Did you brainstorm the idea yourself, or were you inspired by someone elses circuit? If you brainstormed the idea yourself...good thinking man! Simple and effective. I am astonished at the thinking power many people have. (Look at me, I'm talking like I'm 78 years old) Still, there's a lot of people who have a talent for thinking and engineering. Ones that I would love to work along side. Good stuff man, keep it up! I have a schematic of a digital capacitance adaptor for measuring the capacitance value of caps from 2pF on up to 10uF I believe. The adaptor can plug into a digital voltmeter set to a 2volt scale, and output the capacitance of the cap under test. You can also use a panel meter instead of a DVM if you want a stand-alone unit. OR you can make a LED/LCD display using an Analog to Digital converter (ICL7107 etc). Lots of options for customizing the display portion. I can send it to you if you like. Also, there's a schematic for an ESR tester here, I think I may end up building this little beauty if I can figure out the value for R1 and a suitable OPamp part number: http://www.albany.net/~gwoods/esr_me...ter_index.html | |
| Zach, for some reason, ESR (effective series resistance) has been touted lately as the ONLY decent test for capacitors by some folks. You know, we old timers have been checking caps for a long, long time before "ESR" became such a buzz word. In the vacuum tube days, a value check and a leakage test was more definitive than anything else and we did it with RC bridges that set us back $24.95 new! Low on funds? You can't be so low that you can't bid on ebay for a Knight-Kit KG-670 or EICO 950B or other kit RC bridge that you can probably get for a song. A couple more bucks to refurbish it and you'll have a decent instrument that'll be really handy on the bench. ESR is more of a problem with modern, high-current, solid state circuits where the ESR can cause a significant voltage drop within the cap. ESR is rarely a problem (an increase in ESR) with anything other than electrolytic caps anyway. Dean
Almost all capacitor failures these days are electrolytics with low ESR, you can't find these with a bridge (they still read the same value), or with a leakage test (they don't leak any more than normal). You can easily find them with an ESR meter, in circuit as well, or you can find them by measuring the ripple with a scope - which is what I did before I built an ESR meter. I suspect the main problem is down to the cheaper manufacturing of electrolytics, and the widespread use of switch-mode power supplies. But mostly cheap capacitors, the older switchmode supplies didn't have any where near as many problems!. | ||
| Thanx for all the feedback. I didn't understand half of the tests u were talkin about though (never heard of 'em). What is effective series resistance?? I looked @ johnson's circuit (thanx) but didnt understand it. By the way, i did think up the idea myself 8) , although i got the circuit out of a book. a neat little mod i made to the circuit is i took some . . . wuddya call 'em? ic jumpers? u know, the things you solder into a circuit and then you can plug in different ic's. Anyways, i cut them so that you can plug caps into them. I didn't quite get how to do a leakage test, could u explain that a little more nigel? Lastly, wut is a bridge? is a bridge the same as an rc bridge? As for bidding, i'm only 15 and dont have a job Thanx a LOT for all the feeback
| | (permalink) | ||||
It's more important for servicing than just testing capacitors out of your junk box. Quote:
| Still, Nigel, ESR is not nearly the bugger for a 30µF cap in a 350v, 60ma supply that it is when working with 100,000µF (100mF) in a 5v, 50A supply where the cap is moving a lot of current where the I²R drop of the ESR becomes a significant factor compared to the supply voltage. I'll be that bad caps show up a lot more often today because of switchers where there's little secondary DC regulation. In the 1970's where linear regulation of each individual supply often compensated for increasing ripple, bad caps in the raw supply often went undiagnosed long after they should have been replaced. More than once, you didn't see DC supply ripple in a Tek oscilloscope unless the raw supply filter cap was darned-near open! One must look at the situation, too. A marginal cap in a power amp or table radio isn't noticed while one in an audio preamp or mixer may show up quickly. Still, I've been messing with electronics as a hobby and/or professionally since around 1962, and haven't found that I've been hindered by the lack of an ESR meter. If I had to put the cap test items I'd want in order of importance, a cheap bridge would be at the top of the list since it can measure value and check leakage; then would come the ESR meter. I can own ten ESR meters and won't be able to make the other two tests with them. For that matter, I've also done OK without an RF sweep generator, a flutter meter, an IM distortion analyzer ..... :-) Dean
| ahh, i understand now. i think (for the time being) that ill just stick w/ my trusty ol' metronome
| | (permalink) | ||
