Hi, I'm pulling my hair out trying to decide which would be the "best" scope for me as far as reliability, value, usability, etc etc.... I'm just looking for a general purpose bench scope so I know any of these in this list would work fine just want to know if any are more desirable then others. Here is my list of candidates all are Tektronix scopes: 2236 Used 2336YA Used 2246 Brand new old stock! 475A Brand new old stock! TAS475 Brand new! TDS410A Used Well there you go! Any feedback would be appreciated! Thanks!!! Last edited by Strosek; 6th May 2009 at 04:14 PM. | |
I have 475A and I love it.
It depends upon whether you want an analog or digital oscilloscope since some on your list are analog and some are digital. Analog scopes are good for low level, low noise analog signals in particular. Digital scopes have additional features such as built-in waveform measurements, infinite storage time of a waveform, storage of more than one waveform, and easy single-shot waveform capture. Their disadvantages include possibly higher noise level when looking at low level analog signals. and possible alias effects (phantom low frequency signals) when observing high frequency signals at slow sweep speeds. I prefer digital scopes due to their added features, but it all depends on your needs and preferences.
__________________ Carl Curmudgeon Elektroniker | |
Will I ended up buying the Tektronix TDS410A! I hope I did OK... Does anyone have any opinions on that model? Also what would be my best bet as a far as a good set of probes for this unit? Thanks! | |
That scope looks like a good model. Don't know about particular probe manufacturers (Tektronix is probably the best, but also quite expensive) but I suggest a probe with about a 200MHz BW, and 1X and 10X settings. The 1X 10X settings allows you to use a 10X setting, which gives a 10MΩ, low capacitance input for high frequency signals but with a 10 times reduction in sensitivity, or 1X setting which gives a 1MΩ, higher capacitance input for low frequency signals with full sensitivity. An example is Circuit Specialists Inc. - 200 MHz 1X/10X Oscilloscope Probe (5806A). But the above probe does not have a readout actuator so that the vertical sensitivity indication is automatically changed with the probe sensitivity setting, which I believe your oscilloscope can detect. An example with readout is Circuit Specialists Inc. - 250MHz Scope Probe Set w Readout Function, Isolated BNC (HP-9258R), but that's only a 10X unit. Haven't found a low cost unit with both 1X, 10X and readout.
| | #6 |
I just purchased a set of probes that also don't have the vertical sensitivity indication pin....? Will they still work with this unit or should I try to return them? Thanks! | |
| | #7 |
They will work fine. You just have to remember that the sensitivity is 10X less than the oscilloscope setting when using a 10X probe (i.e. if the scope setting is 100mV/div your actual sensitivity is 1V/div).
| | #8 |
Which Tektronix part numbers should I be looking for that will have the switchable 1x and 10x switch AND have the readout pin that will work properly with my new scope. I just want one good set of "all purpose" probes and I'm fine buying original parts. Thanks for your help!! | |
| | #9 |
| Utility - Wikipedia, the free encyclopedia Everyone's is different. If my utility for a woman smiling at me is +10, then my utility for losing a dollar may be -20. Currently, my utility for dying in a non-heroic way is a very large negative number but it can be calculated. And check this out http://en.wikipedia.org/wiki/God's_utility_function Last edited by Willbe; 8th May 2009 at 03:42 PM. | |
| advice, needed, oscilloscope, tektronix |
| Tektronix 336 oscilloscope | James111 | General Electronics Chat | 0 | 6th November 2008 03:31 AM |
| Turning soundcard into oscilloscope - advice | MrNobody | General Electronics Chat | 13 | 28th May 2008 08:29 AM |
| Tektronix Oscilloscope/Digital Analyzer | Fred.Amoson | General Electronics Chat | 8 | 24th May 2007 11:47 PM |
| Oscilloscope repair help needed | hadihf | General Electronics Chat | 11 | 14th April 2007 08:10 AM |
| Oscilloscope advice | Gandledorf | General Electronics Chat | 8 | 7th February 2004 09:05 AM |
