My shop vac stopped working and I diagnosed the problem to be a blown thermal fuse. I have checked with the manufacturer and other sources and haven't come up with the size to replace it. Personally I don't have a clue, but I suspect it is less than 100 degrees Celsius. Does anyone know or have any suggestions? Thanks, Bill | |
There should be a part# or temp marked on it.
__________________ gerty | |
It has no markings, actually it is a piece of metal (wire) between two electrical connections. I am assuming it is a thermal fuse, can't imagine what else it could be, anyway it interrupts the circuit not allowing it to work..
I also have found discarded shop vacs with this device non-operational. My guess is that these "fuses" are included in the design because of product liability concerns. If the motor were to catch fire and consume the plastic, noxious fumes along with the possibility of fire would occur. These fuses are what I call "fail soft" devices. Unfortunately, they are not fail-soft as far as the utility of the vacuum goes. It doesn't make any difference if your vacuum is dead because the motor burned up or the fuse melted. The vacuum is considered junk either way. Too costly to take it to a repair shop. Very few of us attempt repairs and when we do, we cannot find parts. I found a similar fuse INSIDE of a condensor motor case on a Maytag rollaround portable A/C unit. The unit had to be nearly entirely disassembled to get to the fuse. The biggest challenge was to find suitable crinmp connectors as soldering is near impossible. Cost? $1.37 or the part. New unit? $600. By the way, I suspect that the "link" material in the shop vacs is no more than a length of solder. Melting points of different solders can be found at RF Cafe - Solder Properties Melting Point After fooling around with my found vacuum, I ended up bypassing the device. My 30 year old Sears Craftsman doesn't have one and is still running.
Just diagnosed the exact same thing on my ShopVac 90L500A. Blown fuse for which I can't find any specs. Just a piece of metal material between two contacts in an unmarked plastic holder. $100 vacuum tanked by a $0.001 piece of metal. I swear it almost looks like it was meant to wear out after a certain number of motor starts. I don't think I'll be buying ShopVac brand again. Argghhhh!
| | #6 |
Shop Vac warranties their vacuum motors for 5 years home use. If you have the receipt, contact them and they should send a whole new motor. (Their accountants must have figured that a $71 motor is cheaper than a .001 cent fuse.)
| | #7 | ||
Just out of curiosity, how long had the motor been running when it stopped?If they are within the 5-year warranty (But read the fine print first!), then what do you have to loose by returning them. ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |||
| | #8 |
I purchased several thermal fuses at $1.25 an installed the lowest temperature one (165 degres F, I think) I used wire nuts rather than solder. It is working fine now.
| | #9 |
I don't know how long I had it, because I have two. I suspect it is over five years old. The $1.25 thermal fuse was a quick fix, just wish I knew for sure the 165F was low enough.
| | #10 |
Bill, By "how long had the motor been running when it stopped?", I meant running at that moment. Five minutes?...fifteen?...an hour? Ken
| | #11 |
I just went to use it one day and it didn't work. I have had problems with the switch several times and just thought it was the switch, but diagnosed a problem to be the motor. After checking the windings and brushes, I found the problem to be something I thought was a thernal fuse. I replaced it a 165 ͦF thermal fuse, using small wire nuts. Now it is working fine.
| | #12 |
Aunt has this vac and we are helping her out with this. She said she probably was using the vac an hour at least and then it just quit. Husband tore it apart and found this fuse? was burned up. Where can we buy a thermal fuse? What kind of vacuum should we buy for her now? She doesn't want this as she feels it will be unsafe, so we will bring it home and fix it for our shop. I don't think it will be a shop vac model though!! This vac was only used on weekends and a few weeks during the summer as it is used at her summer home. Thanks for your help, Alanis | |
| | #13 |
I did a Google search for thermal fuses and purchased several thermal fuses at $1.25 each an installed the lowest temperature one (165 degrees F, I think) I used wire nuts rather than solder. I figured 165 degrees wouldn't cause a fire and if it too low, it would blow and I would go to the next higher temperature. My largest was 100 drgrees C (212 F). be sure not to solder it in, because it may melt it.
| | #14 |
Thanks for the info Bill! My husband wanted to wire it directly and use it then unplug when we are done. How long has yours lasted since you changed the fuse? | |
| | #15 |
I fixed it maybe three months ago, but only use it in the garage. I expect it to last a long time.
| fuse, motor, shop, size, temperature, thermal, vac |
| Thermal fuse ? | ClydeCrashKop | Datasheet/Parts Requests | 5 | 2nd September 2007 10:41 PM |
| Question about relating thermal fuse ratings | omgwtfbyobbq | General Electronics Chat | 5 | 4th July 2007 10:54 PM |
| Thermal fuse/cutouts | mahinda jayasinghe | General Electronics Chat | 1 | 6th April 2005 02:11 AM |
| Looking for a thermal fuse for my Dryer | ftjn052 | Datasheet/Parts Requests | 1 | 24th August 2003 11:06 PM |
| Looking for a thermal fuse | johanm | General Electronics Chat | 6 | 2nd June 2003 05:41 PM |
