| | #16 |
I had this same problem occur with my shop-vac. Fortunately I happened to have an old eureka vacuum cleaner with a bad cord that I didn't have the heart to throw away. I tore it apart and found the thermal cutoff screwed to the motor housing. I am not sure what the rating is on the eureka cutoff but after cutting the heat-shrink tubing off of it (to eliminate any insulation for the thermal switch) and placing it in approximately the same position as the original in my shop-vac it works great. I have not had it kick off yet and even if it does I can just let it cool down and it will reset. Hope this helps.
| | #17 | |
![]() Looking for a replacement for my daughter's PIZZAZZ pizza baker. I can find them but: one on eBay for $11+shipping, or 10 (minimum order) from the fuse manufacturer for $26 with shipping. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 2nd August 2009 at 11:26 PM. | ||
| | #18 |
Ken, check out this website where I bought mine. Bill Thermal Fuses at Goodman's Small Appliance & Housewares | |
| | #19 |
Now that looks do-able. Thanks! I'll bookmark that resource.ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| | #20 |
Check out the thermal protection used in most modern household vacuum cleaners. According to the instructions supplied with said vacuums if the motor overheats the fuse will kill the motor. If this happens simply allow the motor time to cool while you clean the filters or change the bag to ensure proper airflow the fuse will reset and you are off to the races.
| | #21 |
Check out this site Thermtrol Corporation - Our Products They are the manufacturer of the protection device. | |
| | #22 |
I posted a link to Thermtrol the manufacturer but it doesn't seem to be up yet. The device I found in my eureka vacuum appears to be a SX8AM Series thermal protection device which is shown on the Thermtrol website. I does state that you have to remove power in order for the fuse to reset, so besides cooling down I will have to unplug my shop-vac. | |
| | #23 |
Yes, I'm aware of resettable over-temperature protection devices, but they are not "thermal fuses". They wouldn't fit into the location of a thermal fuse. Ken
| | #24 |
I had to remove the yellow block that held the original thermal fuse entirely from my shop-vac. I will disassemble my shop-vac and get a couple of pictures to show you how it all fit together.
| | #25 |
The thermal fuse is for a PIZZAZZZ pizza baker, not a shop vac. But thanks. ![]() Ken
| | #26 |
Sorry, this tread was started with a question about a shop-vac. | |
| | #27 |
I work for a large hardware store and do repairs on the Shop Vacs that are returned when they quit working. In 95% of the caseas the thermal fuse has opened and an ammeter reading ( oscilloscope monitored for peak inrush) plus an analog meter, show no motor defect . Requests to shopvac for additional replacemenmt fuses go unanswered. Basic product is OK. Service is NOT. Recommend do not buy. I install a fuse holder and put in an appropriate slo-blow fuse reacheable from the outside of the case. Non UL acceptable but in over 75 cases the customer was pleased. Last edited by islandmerv; 25th October 2009 at 12:06 AM. Reason: spelling correctionhs | |
| | #28 |
Too bad they couldn't have splurged for a resettable fuse of the appropriate rating... It's sad to see a good name like this have problems like that over a trivial preventable issue.
| fuse, motor, shop, size, temperature, thermal, vac |
| Thermal fuse ? | ClydeCrashKop | Datasheet/Parts Requests | 5 | 2nd September 2007 10:41 PM |
| Question about relating thermal fuse ratings | omgwtfbyobbq | General Electronics Chat | 5 | 4th July 2007 10:54 PM |
| Thermal fuse/cutouts | mahinda jayasinghe | General Electronics Chat | 1 | 6th April 2005 02:11 AM |
| Looking for a thermal fuse for my Dryer | ftjn052 | Datasheet/Parts Requests | 1 | 24th August 2003 11:06 PM |
| Looking for a thermal fuse | johanm | General Electronics Chat | 6 | 2nd June 2003 05:41 PM |
