Old 25th March 2003, 06:15 PM   (permalink)
Default Motor run caps
I need >300uf of motor run capacitors. But these are very expensive. Is there any other type of capacitor that might perform the same ? (non polarised electrolytics maybe ?)
I want the use an induction(750W, 1360rpm) motor as an alternator.
Thanks,
-Chris
Prof.Insane is offline
Old 26th March 2003, 02:02 PM   (permalink)
If you are looking to save money, consider salvaging the caps you need from discarded units. Check with applicance and HVAC dealers. Even though a washing machine or air conditioner is in the trash pile, the caps inside may be fine. Motor start capacitors are used on virtually every commercial motor application out there. Good Luck!
Gene is offline
Old 26th March 2003, 02:59 PM   (permalink)
Default Induction Motor as Alternator ?
How are you planning to produce a magnetic field in the rotor ?
For caps - I wonder how the power factor cap from an old fluorescent lamp would cope.
I need a memory upgrade ...
My head is full !
mechie is offline
Old 26th March 2003, 05:21 PM   (permalink)
Default Alternator
Mechie, this site says if you put enough run caps in parallel with an induction motor it will produce power....
http://www.qsl.net/ns8o/Induction_Generator.html
I already have a *massive* 9uf collected up. Thats just from some junk stuff I had. lol, just seems like it will take forever to find enough junk caps...
What's different from a run cap to a normal cap anyway ?
-Chris
Old 26th March 2003, 05:23 PM   (permalink)
the name?
bogdanfirst is offline
Old 26th March 2003, 07:55 PM   (permalink)
When power is applied to a larger motor, it must overcome the 'at rest' state to get running. A large (usually oil filled) cap can give the motor a 'hot-foot' to get it running. Once it has attained ( a majority of) its rated RPM, the power suplied can keep it running.
Gene is offline
Old 27th March 2003, 05:17 PM   (permalink)
so how is it connected to the motor?
Old 28th March 2003, 08:01 AM   (permalink)
Default In parallel
"By adding capacitors in parallel with the motor power leads"
-Chris
Old 28th March 2003, 04:37 PM   (permalink)
Default Motor capacitors
OK, the website looks believable...
Induction Motors are available in different types for different purposes...
If a motor is required to have a predictable direction then it will have a start capacitor (a cap-start motor), the motor has two windings with one being the full-time 'running' winding and the other (in series with the capacitor AND a centrifugial switch) is only used to start the motor and accelerate it up to around half-speed when the centrifugial switch will open and the motor runs on the single 'running' winding.
These motors take about SEVEN times as much power to start as they do to run due to the low impedance of this 'start' winding.
During the start they are effectively two-phase motors, the cap giving some phase-shift for the second winding.
A second design (the cap-run motor) has a much higher 'start' winding impedance so that its current is much lower and there is no centrifugial switch. The 'start' winding now stays in circuit all the time and the motor will cope with bigger loads but will be poorer on starting.
Another design adds a third winding and another capacitor. There is now a 'start' winding (with centrifugial switch) and the two 'run' windings. These cap-start, cap-run motors are more complex and so cost more.
OK, so the capacitors ...
start capacitors are NOT capable of sustained operation - don't use them!
run capacitors expect to see continuous duty so are the type you require.
If you have only a few uF I guess they are not motor caps.
As you live in the UK I will suggest RadioSpares (http://rswww.com) for new caps (or info anyway!)
A 50uF motor-run cap is £12.98 + VAT (stock code 377-8879)
### IMPORTANT ###
The website assumes 120vAC mains at 60Hz, the UK (as you know) has 240v at 50Hz.
The website talks vaguely of speeds and having to 'overspeed' the motor. This is a simple issue of 'magnetic slip' in the motor. The rotor has to move slower than the magnetic field in order to induce into the rotor's windings. You are going to reverse this effect and have to rotate faster than the field you hope to generate.
The motor's dataplate will give a speed (probably 1480rpm or 2940rpm), notice these are both just slower than the UK mains 3000rpm (or 1500rpm for a four-pole device), you need to exceed the mains speed by about the same amount.
Exceeding this speed significantly could cause the motor to 'shatter' with centrifugial forces. Too slow and it won't generate?
The frequency you generate will be a function of this speed and the load on it.
DO NOT GET CASUAL WITH 240v It Can KILL !
The capacitors WILL BITE if you touch them while the 'generator' is working.
Hope this helps... :wink:
My head is full !
mechie is offline
Old 29th March 2003, 07:35 PM   (permalink)
Default Ta
Thanks Mech, and everyone else!
Ill see if I can get some scrap caps somewhere. One more question... Is there anyway to tell if they've blown up ?
Thanks again.
-Chris
