+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 25
Thread: Full wave rectifier from a wall wart?
  1. #1
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    Default Full wave rectifier from a wall wart?
    I would like to build a variable +/- power supply from a 15volt wall wart.
    Can i put in a full wave rectifier or just a half wave?
    If i can where does the ground go?
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    Is the wall wart AC or DC out?
    Bill
    Smart Kits build Smart People
  3. #3
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    sorry yeah ac ... for a dual supply
    edit: thanks for the quick reply
  4. #4
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    You need two half waves- to separate the positive and negative AC from each if you want a dual supply. A full-wave would just grab take both the positive and negative AC and make it one polarity.
  5. #5
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    ok thanks
  6. #6
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    YOu could also use two full-wave rectifiers to do the same thing. Added complexity though and since you want a dual supply, you have a use for both positive and negative waveform. (If you only needed one polarity, using a half-wave would make no use of every half cycle and also increase output ripple).
    Two full-wave rectifiers would produce a smoother output though. (Rather than grabbing every second cycle for positive or negative output like dual half-waves, it would take each half cycle whether it be positive or negative, and split it between positive and negative output.)
  7. #7
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,076
    This circuit will work, for a ripple of 2V use 1000:mu:F per 100mA of load current.
    The output voltage will be just over 20V.
    If you want 15V add an LM78L15 and LM79L15.
    The capacitor values shown below with the aforementioned regulators added will be able to supply up to 100mA with 15V in.
    if I know the answer.
  8. #8
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    So that would be half wave yes? Is there and way of makeing that full wave without resorting to a centre tap transformer?
  9. #9
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    Im thinking i should just forget the wall wart... wanted to go that route as i didnt want to dable in 230v...
    Hot does this one look to you guys? Seems simple enough
    C1, C2 2 2200uF 35V Electrolytic Capacitor
    C3, C4, C5, C7 4 1uF 35V Electrolytic Capacitor
    C6, C8 2 100uF 35V Electrolytic Capacitor
    R1, R4 2 5K Pot
    R2, R3 2 240 Ohm 1/4 W Resistor
    BR1 1 2A 30V Bridge Rectifier
    U1 1 LM317 Adjustable Positive Regulator
    U2 1 LM337 Adjustable Negative Regulator
    T1 1 30V Center Tapped 2 Amp Transformer
    S1 1 SPST 2 Amp Switch
    It seems simple enough
  10. #10
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,076
    Read my previous post!
    You can't use a centre tapped transformer because I thought you were using a wallwart and those things don't have a centre tap.
  11. #11
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,264
    Blog Entries
    2
    No center tap on a wall power pack?
    It must be a UK thing. I have taken dozens of them apart for specialty projects and I would confidently say at least 3/4 of them have center taps around here.
    I learned something new too!
    "When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
  12. #12
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    Yeah thats why i was saying i think i should forget that route.
    The power supply will be needed to run at +/-9v to run 6 of these (see link) in place of the 9 volt batteries.
    Singing plants, advice please.
    The reason i want to make it variable is so i can run it in other projects later.
  13. #13
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,859
    The circuit you posted from Aaron Cake's site has the wrong values for its voltage-setting resistors and pots. It has the values for the more expensive LM117 and LM137 regulators. Using those values with LM317 and LM337 regulators will cause the output voltages to rise when the load current is low.
  14. #14
    steve_j83 Newbie
    Join Date
    Mar 2009
    Posts
    37
    ooohhh not good, thanks for the heads up Mr audio
  15. #15
    Join Date
    Feb 2009
    Location
    Posts
    3,264
    Blog Entries
    2
    If your planning to run other things off of it you may want to think about building it with two transformers. That way you can stack them if you need dual voltage or a higher voltage and they could be or put in parallel for more current. Plus your total available power is higher.
    The total parts are about the same but you would gain some added versatility. If you needed two independent power sources you would have them available too.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Full - Wave Rectifier needs help
    By stivfk in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th January 2009, 03:26 AM
  2. Question about current in a center-tapped full-wave rectifier circuit
    By IhavenoeffinName!! in forum General Electronics Chat
    Latest: 15th April 2008, 01:12 AM
  3. Wall Wart
    By proteus999 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th November 2007, 03:14 PM
  4. Help! Full Wave Rectifier Bridge Network
    By benboards in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th February 2004, 09:10 AM
  5. full-wave bridge rectifier problem
    By MsStateDawg in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th January 2004, 06:52 PM
Tags for this Thread
