Im trying to modify a motion sensor to run off of battery power. All the circut is running off of 5 volt except I think the main ic is looking at the zero crossing from the ac line Anyone have any suggestion how i can simulate this? The location is were r11 and r12 conect. here is a picture of the circuit http://home.earthlink.net/~imsteveo/images/desa1bg2.bmp | |
For motion detectors no need zerocross detection from mains. I mean, this PCB coming from an outdoor lamp with motion detector. In this case - i think - this is an additional flip-flop circuit for continous light. (few years ago i've made some reverse-engineering) In my circuit, when the power switch pushed quickly twice, the lamp go to continous mode... | |
I guess you are rigtht reading the user manual it does have a manual override by flipping the switch off and on for 1 sec. Any suggestion? tips on this board ? The board seems to semi work when r11 and r12 removed and left the ic floating. I did try to inject a 60 hz at R11/R12 with a 555, but no luck | |
| | #4 | |
If possible, put a photo about component side, i try some rev.eng. on this weekend...
| | #6 |
Sure I be happy too!! Ignore the wires in place of the relay ( I added a buzzer for testing ). http://home.earthlink.net/~imsteveo/...d_dsc_0207.jpg http://home.earthlink.net/~imsteveo/...d_dsc_0217.jpg Thanks for looking | |
| | #7 |
My first impressions: C12, R20, Q4, ZD3, C13 is a regulator circuit with U_zd3-0.7V output voltage, probably about 12V. So: first connect the DC voltage direct to C12, min 14V,maximum as capacitor data shown.
| | #8 |
Are you covering the photocell, for testing purposes??
__________________ gerty | |
| | #9 |
Here is the circuit of transformerless power supply section. As gerty suggested, the CDS LDR must be covered, because it blocked the PIR sensor.
| | #10 |
Nice drawing I have the battery (9v) connected just like you said. Sensor is covered with a pencil eraser. I do have 5 volts across C13. The board will not operate until i disconect R12 , R11 and let the trace to the ic "float". steveo | |
| | #11 |
O.K. You can try one more thing: put a 10k resistor to R12 position, and to this IC point a pushbutton to GND.Now the pushbutton work as the manual said. Some functions depend from slide switch.Maybe after power on the internal flip-flop always going to blocked state.
| | #12 |
Well tried the 10 k resistor, and push button switch ( tapping jumper to gnd), but still no luck. note i'm leaving the slide switch in "test mode" as i assume this ignores the ldr and lest you adjust the sensor during daylight. I'm still woundering why R11 (1meg) is there, going to the AC line. Steveo | |
| | #13 |
This resistor feed the pulse from mains switch to flip-flop. Are You sure the circuit was good before experiments? Unfortunately hard to rev.eng. this surface mounted IC. | |
| | #14 |
Yes If I put every thing back the way is was. The sensor will work I done it many times. Thanks for trying to help! Steveo | |
| cross, dectect, needed, suggestion |
