+ Reply to Thread
Results 1 to 9 of 9
Thread: Where do I find a wire connector for this part?
  1. #1
    FarSeer Newbie
    Join Date
    Apr 2009
    Posts
    5
    Default Where do I find a wire connector for this part?
    Please excuse my ignorance here, but I have very little idea of what I've gotten myself into. I need to extend the length of the ribbon on this membrane switch from the circuit board with wires for flexibility. The problem is, I have no idea what I'm looking for or where to look.
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    You didn't attach a picture.
    If you just want wires on your membrane switch, then a through hole PCB connector can be used to solder wires to. It really depends on what type of flex cable you have. Type "flex" into the search engine at Digikey or other supplier to find more.
  3. #3
    FarSeer Newbie
    Join Date
    Apr 2009
    Posts
    5
    I forgot about the pictures! I added them to the first post.
  4. #4
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Measure the spacing between the pin holes of the connector. If there are a .1" centers you might be able to build your own extension cable from header connector parts like this, cut down to 3 terminals:
    SparkFun Electronics - 6 Pin Right Angle Male SMD Header
    Lefty
    Measurement changes behavior
  5. #5
    FarSeer Newbie
    Join Date
    Apr 2009
    Posts
    5
    They are .1" apart. Thanks for your help. I was able to find both the male and female headers.
  6. #6
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Use a servo extension cable, should be able to find them in any RC hobby store, not gonna be flat cable but it may be flexible enough. If that connector isn't completly fused shut you may be able to open it and tap the leads directly.
    straight answer, har har."
  7. #7
    FarSeer Newbie
    Join Date
    Apr 2009
    Posts
    5
    I don't see any way to get into that connector. I might be better off building a cable or using a servo extension cable.
  8. #8
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Servo extension cables are often over priced, you'd be better off making your own if you're not going to pay an arm and a leg for shipping.
  9. #9
    FarSeer Newbie
    Join Date
    Apr 2009
    Posts
    5
    Good point. That's what I'll do then.
+ Reply to Thread
  1. Trying to find a simple connector
    By maz59 in forum Datasheet/Parts Requests
    Latest: 25th January 2009, 09:25 PM
  2. Connector for 4-wire touch panel...
    By AceOfHearts in forum General Electronics Chat
    Latest: 28th July 2008, 12:06 AM
  3. Part number for this connector
    By 2camjohn in forum Datasheet/Parts Requests
    Latest: 11th February 2008, 02:35 AM
  4. Need to find a connector
    By gulaz in forum General Electronics Chat
    Latest: 24th February 2004, 03:55 AM
  5. Find Shell For Cinch Connector
    By shermaine in forum General Electronics Chat
    Latest: 12th February 2004, 05:09 AM
Tags for this Thread
