+ Reply to Thread
Results 1 to 8 of 8
Thread: Converting AC to Dc and tracking parameters
  1. #1
    Wond3rboy Okay
    Join Date
    Jun 2008
    Location
    Hyderabad,Pakistan
    Posts
    472
    Blog Entries
    2
    Default Converting AC to Dc and tracking parameters
    Hi i want to convert 220Vac in to ttl levels or a small DC voltage(<10v) but want to keep track of the parameters(particularly current).I know that a transformer will vary both so can i still map them or not?Any other ideas.
    Thanks.
  2. #2
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,028
    Generally, if you're lucky enough to have AC to start with, you want to step it down as much as possible while it is AC before converting it to DC. THis is because it is much easier to efficiently step down AC than DC (you just use a transformer, while to do the same thing you have to use switching converters which basically turn DC back into AC to be stepped down and then converted back into DC again).
    You can just stick a current sensor to measure the DC...there isn't any real point to measure the AC and it's also more difficult. YOu can always work backwards with some math and find out approximately how much AC current you are drawing from your DC measurements.
  3. #3
    Wond3rboy Okay
    Join Date
    Jun 2008
    Location
    Hyderabad,Pakistan
    Posts
    472
    Blog Entries
    2
    I do intend to use a transformer but i want to know wil i be able to track the variation in current and to successfuly map them for a digital input(microcontroller). I want to check for a lamps short circuit current and normal operation current.
  4. #4
    Thunderchild Good Thunderchild Good Thunderchild Good Thunderchild Good
    Join Date
    Jul 2005
    Location
    UK
    Posts
    2,010
    put a very low resistor on the output and check the voltage drop accross it, use ohms law to work out the current, resistor value depends on the amount of current your talking about
    www.simonsphotography.org.uk/ - My other hobby
    www.rotaract1070.org.uk/ - make a difference and have fun !
    Never buy "Trust" products, all mine broke !!!
  5. #5
    Wond3rboy Okay
    Join Date
    Jun 2008
    Location
    Hyderabad,Pakistan
    Posts
    472
    Blog Entries
    2
    I already worked out the DC part used a pullup and a pulldown resistor combo to detect open and short ciruit.I acheived detecting a short or open ckt of an led but i want to map AC in to DC so it can be applicable.Thinking about measuring the current consumption of the lamp and then doing the math to calculate it at the output of the transformer.Thanks for your reply.
  6. #6
    Join Date
    Jul 2005
    Location
    UK
    Posts
    2,010
    if you want to measure AC amps in do the same with a resistor but retify it before applying it to a pic, i beleive an opamp circuit can provide voltage dropless rectification. I have to say your requests are not entirely clear
  7. #7
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,013
    If you want to safely measure the current and voltage in the 220VAC circuit then you will need two transformers, a voltage transformer across the line and a current transformer in series with the load. The outputs of these can be rectified to give a DC representation of both.
    Carl
    Curmudgeon Elektroniker
  8. #8
    Wond3rboy Okay
    Join Date
    Jun 2008
    Location
    Hyderabad,Pakistan
    Posts
    472
    Blog Entries
    2
    Quote Originally Posted by Thunderchild View Post
    I want to keep the 'integrity' of the parameters(current to be exact) intact when i change the coltage from AC to DC.
    Quote Originally Posted by crutschow View Post
    I will look in to this.
    Thanks for your replies.
+ Reply to Thread
  1. Process Parameters for CMOS
    By analogdesigner in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th February 2009, 04:25 PM
  2. 3 phase motor parameters
    By Shohadawy in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th October 2008, 10:41 AM
  3. theil small parameters
    By Gaston in forum General Electronics Chat
    Latest: 24th June 2007, 02:39 PM
  4. Estimation of Transistor Parameters?
    By DigiTan in forum General Electronics Chat
    Latest: 11th April 2006, 09:28 PM
  5. Transformer parameters.
    By lord loh. in forum General Electronics Chat
    Latest: 26th November 2005, 08:18 PM
Tags for this Thread
