+ Reply to Thread
Page 1 of 3
1 2 3 Last
Results 1 to 15 of 34
Thread: Another power supply question, bi-polar
  1. #1
    Cobalt60 Good Cobalt60 Good Cobalt60 Good
    Join Date
    Feb 2009
    Posts
    125
    Default Another power supply question, bi-polar
    Well, Im just trying to figure out how every little piece of a power supply works exactly. Right now, I am curious about the term "bi-polar power supply". What little understanding I have of these is they they have both a positive polarity and a negative polarity, in addition to a ground, as compared to what I suppose would be called a "uni-polar power supply", which would presumably have only a ground and either a pos or neg.
    So, both linear bench power supplies I use have both pos and neg outputs, in addition to ground, so would I be correct in assuming that those are both bi-polar?
    As far as design, would, for example, my 0-36V variable power supply actually in some sense be a -18V and +18V power supply? I also have to ask at what design stage this comes about, I am thinking it begins with the transformer, but basically Id like to understand the entire design.
    If my assumptions are correct, this means that on, for example, my Power Designs 3650 (0-36V), I could use the pos and ground to achieve a max output of 18V, or neg and ground for -18V. I am not entirely sure of the motivation to do such a thing but by all means Id love to learn some appropriate uses.
    Thanks for teaching me
    -Chris P
  2. #2
    Ayaskanta Good Ayaskanta Good
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    A 0-36 variable suppy mans you get a max. supply of +36V.
    Your bench power supply probably has three knobs. Red, Black and Green(?)
    Red for positive voltage, green for negative and black for ground. In this case the voltage varies from the negative maximum voltage to 0 to positive maximum voltage.
  3. #3
    Join Date
    Feb 2009
    Posts
    125
    My one I have here at home is a Power Designs 3650. The pos is red, and both the neg and gnd are black. Its voltage is adjustable between 0 and +36V. My one at work may have green for negative, I cant remember at the moment, but that one too adjusts between 0 and about +31V.
    On both, their advertised voltage range is achieved by using pos and neg, and leaving ground unused. Actually none of us at work really know what the ground terminal is used for... So far every use I have had for a power supply is the equivalent of using it in place of a battery.
  4. #4
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    Oh is it? Well, its always safer to use the ground. There is a meter(indicator for voltage) right? Does the scale vary from 0 to the max. value or does it include negative scale?
  5. #5
    Join Date
    Feb 2009
    Posts
    125
    Well I just physically tested a DC fan using the pos and gnd, no power. So...
  6. #6
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,026
    The ground on a single output (unipolar) supply is connected to the case and the ground prong on the power cord. It is mainly for safety and, in some cases, to provide a high frequency ground path. It is normally isolated from any of the supply circuitry (you can check that with an ohmmeter). Thus you can not get +18V and a -18V from a single 36V supply.
    Carl
    Curmudgeon Elektroniker
  7. #7
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    Quote Originally Posted by Cobalt60 View Post
    U mean the fan didn't run? Funny! Well here(in India) we've always used Red and Black. Infact the lab attender threatened us and asked us not to touch the green knob
  8. #8
    Join Date
    Feb 2009
    Posts
    125
    The one I have here has an analog gauge, 0 through 36V, as well as 0 through 5A. My one at work has a digital display, I dont think Ive ever seen it show a negative reading, and at work we all use the neg and not ground. So far I have not noticed much of a functionality difference between the two power supplies.
  9. #9
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    Check out the meter range. It'll give you an idea if your supply is 0-36V or -18V to +18V
  10. #10
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Is the bench supply isolated? The + and - leads would be for the power supply relative voltages, the GND connection is just there if you need a refrence ground, probably goes to saftey ground on the wall outlet, and the case itself as well.
    straight answer, har har."
  11. #11
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    Hmph.. well you sure the two knobs are black? My friends and I were getting confused with the colours in school... sometimes they use a very dark bottle green-blackish colour for the green knob
    As far as I know.. when the black and the green knobs are used then your supply provides you with negative voltage...
  12. #12
    Join Date
    Feb 2009
    Posts
    125
    My bench supply has ground, negative, and positive terminals, but is only advertised as a 0 through +36V supply, is this a bi-polar supply?
    And yes, the fan did not run. To get power on this supply I must use the pos and neg terminals. However, the power supply is old and I am not 100% sure that it is fully functional.
  13. #13
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    Now you didn't mention that one!
  14. #14
    Join Date
    Feb 2009
    Posts
    125
    So are my bench supplies bi-polar or uni-polar? Somewhere internal to the design is there indeed a -18V and +18V?
    And indeed the fan did not work when connected to pos and gnd. I suppose if the grounds are isolated that would make sense. And my supply here is definitely a red and 2 black, at work I just cant remember.
    So how exactly would I use a "reference ground"?
  15. #15
    Join Date
    Mar 2009
    Location
    Bangalore, India
    Posts
    105
    Red face
    I really can't work out the range!!! (I've very poor practical knowledge, sorry). I really hope someone helps you Try this... (I hope its safe) Turn your voltage varying knob to its maximum, use a DMM and check its voltage... repeat this with red-black, green-black combinations.
+ Reply to Thread
Page 1 of 3
1 2 3 Last
  1. power supply question
    By MartinHazel in forum General Electronics Chat
    Latest: 14th March 2009, 07:56 PM
  2. power supply question
    By firealarmfrea785 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th May 2008, 03:27 AM
  3. Power Supply Question
    By brittam in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th July 2007, 08:54 PM
  4. power supply question
    By iONic in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd June 2007, 02:45 AM
  5. power supply question
    By raphaelriv in forum General Electronics Chat
    Latest: 22nd March 2007, 06:39 PM
Tags for this Thread
