Hi I have located a chip on my lapop and I am trying to find the manufacturer , it is marked with a funny shaped f as if that is the company logo mark , does anyone have any idea as what the company could be . cheers | |
Take a clear photo and post it.
Hi thanks for your reply , it is not possible to take a photo of it , it is to small and it melted somewhat , I have had to read what was on it with quite a strong magnifier . ps: the marks on it are P32AH and below this 66806 there was some other numbers on it but i can not read them . cheers cheers | |
Take your board to a pro for repair. Lets just say that you find a replacement for that burned chip...what do you do then??? Do you slap it in to replace the original...you know what'll happen????...it will burn out as well. Unless you fix the actual problem, anything you plug in will burn up, just like the original. As well, If you can actually see a melted chip on a Motherboard, there will probibly be a dozen other devices that have burned out...that cant be seem by the naked eye. Motherboards are not considered for "Home Repair", and are difficult for even a pro to fix. | |
I agree that the repair could be more difficult then repairing the chip. But I would be suprised to find a place doing anything other then a MB replacement in this case. If so there is little to loose. It he is very lucky we may find some help regarding the problem on the web. Does the chip have this logo. It is fairchild
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #6 |
Your reply doesnt make sense. I chip doesnt usually just commit suicide, and burns up, so there is another fault o the board. He does have something to lose, he could bugger up his board doing a self-repair, or take it to a pro, and get it properly fixed. I dont think we do anyone a service giving someone with little or no experience just enough info to kill off a expensive piece of equipment, that could be prroperly repaired by someone with proper desoldering/soldering equipment, and the knowledge to find the real problem | |
| | #7 |
It is unlikely you'll be able to repair it by just replacing that chip. But here is a list of logos to help you out: Manufacturers of ICs and their logos
__________________ Inside every little problem, is a big problem trying to get out. | |
| | #8 |
When a chip goes out on a almost any electrical circuit it comicazies. That is, it does not usualy die alone it takes as many other IC's and components as it can along with it. If it was part of a switching circuit or a regulator circuit it most likely took a pile of other components with it. If it was a logic IC or a sub processor it took everything that its working with down with it! Sorry but your MB is officialy junk! You can take our opinion for free or pay an expert to agree with us. MB death is not cost effective to repair. Its just a sad part of life.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
| | #9 |
Hi all thanks for all your replies , I have desoldered and soldered a couple of tiny transistors on motherboards with success , it is off a dell c640 Laptop , the motherboard works fine off the battery , it is the charging and runing off the PSU that is the problem . cheers | |
| | #10 | |
A repair center will want to install a new MB. They know that it is their best road to profit. We now know the problem is in the charging circuit. I am not saying he can fix if, but the chances have gotten better. If he can ID the chip the chips datsheet may give us/him a hint as to what the associated parts are and what it does. Quote:
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
| | #11 |
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| | #12 |
Hi guy's and gals photo as rquested , I have removed the actual item but the one next to it is the same shape Last edited by spike47; 4th April 2009 at 04:13 PM. | |
| | #13 |
A picture of where the chip was is not very helpful.
| | #14 |
| 3v0 you proved that you've got a nice humor sense!
__________________ Superman returned | |
| | #15 |
It looks more like it could be a FET rather than an IC. Is Q82, the same as Q83 which is the one you removed? Can you post a better closeup of the area and a picture of the device you removed? It looks like the IC marked SZT01J05S is also damaged. It is hard to tell from the photo whether there is a speck of something or a small crater on that chip.
| chip, identifier |
| Help with ISD chip EOM | skinnie339 | Electronic Projects Design/Ideas/Reviews | 2 | 4th March 2009 08:23 PM |
| need a PWM chip | zavedur rahman | Datasheet/Parts Requests | 2 | 3rd August 2007 09:50 PM |
| What chip is this? | EagleVisionTSi | General Electronics Chat | 5 | 25th March 2004 01:16 PM |
| 8-Bit ADC chip | pike | Datasheet/Parts Requests | 2 | 15th March 2004 05:38 AM |
| sim chip | TKS | Micro Controllers | 4 | 25th February 2004 07:19 PM |
