+ Reply to Thread
Page 3 of 5
First 1 2 3 4 5 Last
Results 31 to 45 of 72
Thread: 0.1 uf electrolytic and 0.1 pf capacitors
  1. #31
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    But don't forget, the only strips that matter on bread-board are those connected to the tank circuit and if the adjoining strips are not used, the problem does not exist.
    Don't get me wrong, I would not use bread-board for 100MHz circuits, expecially those that employ Tank Circuits as the Q of the tank section is very important and you cannot expect to get anything out of a circuit that is poorly designed. That's why I brought it to attention. But you can't say that bread-board has a lot of stray capacitance. But it certainly has a lot of unwanted impedance - especially around the tank section, where unwanted (or stray) impedance can be so high that the circuit fails to oscillate completely, or fails when you bring a hand near the oscillator.
  2. #32
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    Colin, I'm not sure why you're having trouble understanding this, the capacitance is there no matter if the row is used or not.
    The capacitance decreases with each neighboring row that is vacant because they're in series, but it's still there. Any circuit over 10-20mhz or so if moved to a project board would have to be retuned. I have heard of many people setting up oscillators on a breadboard that they get to work just like they wanted to and when they move them to point to point or strip board and they don't work anymore because they fail to acount for it.
    Anyone that has used a microcontroller or cmos logic gates and left lines floating knows this because the capacitance is high enough that any nearby floating gates will follow the nearest signal line they can find like a sick little puppy.
    Inductance is an issue as well though I've never seen any static numbers for what kind of inductances there actually are.
    Basically anything over 10mhz you want to work reliably in a real circuit should probably be wire wrapped or point to point soldered, unless you're fine with it working only on the breadboard.
    straight answer, har har."
  3. #33
    Gekko022 Newbie
    Join Date
    Apr 2009
    Posts
    11
    Quote Originally Posted by kchriste View Post
    You could also build AudioGuru's design:
    I definitely don't have all the parts to make that. Does anyone have a schematic for an FM transmitter that is similar to mine but definitely works? and is sensitive.
  4. #34
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    You could chop off the regulator and the additional RF power stage, but it wouldn't be as stable (frequency drift) and wouldn't have the same range (Output power):
  5. #35
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,842
    Quote Originally Posted by colin55 View Post
    I have sold over 100,000 kits and the audio is so good that you cannot tell if someone is talking in the next room or the sound is coming from an FM radio.
    No.
    Your FM transmitters do not have pre-emphasis (treble frequencies boost) like FM radio stations use. So your FM transmitters will sound muffled on an ordinary FM radio because all FM radios have de-emphasis (treble frequencies cut) and therefore your transmitters will sound bad with no treble frequencies like an AM radio or like a stereo with its treble tone control turned all the way down.
    My FM transmitter sounds perfect because it has pre-emphasis.
  6. #36
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    I have already suggested visiting my site and building one of the following FM Bugs:
    See Wasp or Voyager on talkingelectronics.com website for a much-better design
  7. #37
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    You have absolutley no idea what you are talking about.
    An FM station through one of my bugs sounds exactly like the radio station coming from the radio.
    I will be putting your circuit on my website under "Spot The Mistake" as it is one one of the worst layouts I have seen in my life for a 100MHz design.
    I will be showing readers "what not to do."
    I remember the day "strip-board " came in and only an idiot woud use it.
    It doesn't look professional and I would certainly not show anyone I had used it - or recommend its use.
  8. #38
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    Post audio received on your respective devices record them in .wav format with NO alterations of any kind. A modern pop radio station will generally do. A good 30 seconds worth of audio, and since I don't know jack about FM radio design I'll judge the relative quality of the rendered audio. By ear and with through spectrum analysis. And Colin if you look at audioguru's board and think that's "not professional" Then you've got a serious problem! Would you care to post some live photo's of the last few boards you personally made so we know what a real professional is capable of?
  9. #39
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    Obviously you have never made an FM transmitter in your life, so you should not be commenting.
  10. #40
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    Colin, my apologizes. I wasn't commenting about any portion of FM transmitter design. I simply want you to use a common FM receiver to record the audio from your transmitter. Post those .wav clips and I'll judge them, both with my own ear and from a spectrum analyzer, and post my results. For best results you should feed your FM transmitter with hi-fi audio, or better yet, white noise.
  11. #41
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,842
    It does not and please stop arguing.
    FM radios in your country have de-emphasis that cuts 3.2kHz to -3dB, 6.4khz to -6dB and 12.8kHz to -12dB. 15khz is reduced more.
    The 22k collector resistor in the mic preamp transistor of your Wasp transmitter is bypassed with 1nF which cuts 7.3kHz another -3dB and steepens the high frequencies cutoff slope. It will sound very muffled on an FM radio.
    My FM transmitter has pre-emphasis to cancel the de-emphasis in FM radios. My mic preamp transistor has a 10k collector resistor that is bypassed with 470pf so it cuts frequencies above 34khz so that 15kHz sounds good.
    My FM transmitter has a low-dropout voltage regulator so its frequency doesn't change like yours does when the battery voltage is running down.
  12. #42
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    Would you care to post clip audioguru? A local FM station will do, preferably a song I know so I can download an appropriate clip for comparison =)
  13. #43
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    It's the expense of getting the extra components, such as the regulator, and even the enamelled wire, that put even the original poster off building it. That's why I supply kits for everything I produce.
    Alkaline batteries are very expensive and not needed for 30mA circuits.
    Out of more than 100,00 kits, no-one has commented on the fact that the transmitter does not clarity, and returned a kit.
    I have compared the output from a radio and from a bug and could not tell the difference and I have a new $15 hearing aid from China, so I can hear it very clearly now.
  14. #44
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    It looks good to me strip board and all I would love to use strip board but haven't found any one that sells it in the US. And I never had any luck with solder less bread boards and fm transmitter. I all ways had to solder them up on a cheap board you get from radio shack. I don't think that board would look better if it was on a pcb. Very nice work.
    Burt
  15. #45
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,842
    I don't use a 7805 voltage regulator that has a dropout voltage of 2V. I use a low-dropout regulator that has a dropout voltage typically 0.05V or 0.2V max at the low current it is used for. Then my oscillator frequency is stable until the 9V battery voltage drops below 5.2V.
    Doesn't an FM radio sound exactly the same as an AM radio with your hearing aid?
+ Reply to Thread
Page 3 of 5
  1. 3uf Electrolytic Cap to 1.5uf 63V
    By Gregory in forum General Electronics Chat
    Latest: 27th August 2008, 12:39 PM
  2. electrolytic cap ok here?
    By tab a in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th February 2008, 04:20 PM
  3. SMD-electrolytic capacitors
    By Boncuk in forum Datasheet/Parts Requests
    Latest: 31st January 2008, 02:44 PM
  4. How to chek other than Electrolytic Capacitors ?
    By aljamri in forum General Electronics Chat
    Latest: 12th January 2008, 10:17 AM
  5. Electrolytic vs Tantalum at <1V
    By speakerguy79 in forum General Electronics Chat
    Latest: 19th October 2007, 05:21 AM
Tags for this Thread
