| I have got one of those small crystals, packed in a silver package, low-profile, two pins. How do I connect it so that I get the output that is printed on it (7,680)? Cheers! Lac. | |
| It sounds like you are looking for an AC output at the crystal frequency so the crystal is only part of an oscillator. Crystals can also be used in filters.
__________________ stevez | |
| soo..? who do I get the desired frquency from the crystal? | |
| The simply method to build it with CMOS inverters. | |
| w00t!? Don't they need power or anything? Just the crystal, a resistor and an inverter gate, and then I get my square 7,68Khz output?? That looks way too simple and mystic! Cheers! Lac. | |
A crystal by itself is a passive device of sorts. It only reacts to a stimulation input. | ||
:lol: | ||
Also the crystal is more likely to be 7.68MHz, rather than KHz. | ||
| Hm.. I can't get the crystal to generate any frequency at all. I used the first scematic posted over. Cheers! Lac. | |
| Anyone know why I'm not getting any output? Does the resistor have to be 10M? Thats pretty high. Cheers! Lac. | |
| Try this circuit, if you dont have 74HC14 you can use any inverting HC gate... | |
| Does the caps need to be 22pf? Can't I use something bigger, like 1uf? Cheers! Lac. | |
| No.The cap. value depend from quartz freq. With 1uF cannot work. | |
| You can use something similar 10pf-50pf | |
| But doesn't the caps depend on the crystal frequency? I wasn't able to find any datasheets. Cheers! Lac. | |
