+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 21
Thread: Regulators failing
  1. #1
    Diver300 Excellent Diver300 Excellent Diver300 Excellent Diver300 Excellent
    Join Date
    Oct 2007
    Location
    England
    Posts
    1,102
    Default Regulators failing
    I have an LM25576 regulating approximately 12 V down to 4 V. The LM26676 is a buck switching regulator and in my power supply it is rated to 2A. It has a soft start capacitor so that the output voltage comes up fairly slowly.
    From that I am feeding a ZXCL300 to give me 3 V at a few mA.
    The problem is that as I turn on the 12 V, the ZXCL300 sometimes goes up in smoke.
    I've looked at the 4 V line with a scope and there don't seem to be any spikes, but I am not entirely sure. When I switch on the 12 V with a transistor there isn't a spike and I can just see the ramp controlled by the LM25576. There is a 100 uF capacitor on the output of the buck regulator, and a couple of ceramics as well.
    Any ideas?
  2. #2
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    We can't help you with anything unless you post the entire schematic of your circuit.
    straight answer, har har."
  3. #3
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    Why don't you put a couple of diodes to drop the voltage. The chip you are using is obviously a very delicate device.
  4. #4
    Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,927
    Blog Entries
    2
    What is being powered off of the ZXL part? Maybe something is latching up.
    Pay it forward.
    www.geoepicenter.com
  5. #5
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Or the SMPS isn't set up correctly and it's getting straight 12 volts for some fraction of a cycle. There's any number of a hundred things that could be going wrong and we could guess until the cows came home but we can't offer any advice without a schematic. There should be a lock on all threads like this without schematics because they drag on for 3-5 pages and usually then the poster comes out with some random bit of information that if inclded in the original post would have led to an immediate answer. But they get bogged down in what ifs and people aruging about symantics from a circuit that isn't even fully defined.
  6. #6
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    See. The what ifs are already starting =)
  7. #7
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,286
    Blog Entries
    2
    You mean like, What if something, something, something, something, 555 timer IC, something, something, something, something, Microcontroller, something, something, something, something, SMPS, something, something, something, something, super ultra multistage battery charger,something, something, something, something, line harmoncs.
    Is that what you are saying?
    "When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
  8. #8
    Join Date
    Oct 2007
    Location
    England
    Posts
    1,102
    Here is the schematic. I should have posted it when I started the thread.
    I am running a PIC from the 3V line, and using the 3V as the ADC source, so I want a well-regulated voltage.
    I don't think that the PIC is taking excessive current. I've never blown one of them. The ZXCL300 should have thermal shutdown to protect it against too much current.
  9. #9
    sPuDd Newbie
    Join Date
    Mar 2008
    Location
    Australia Atherton Nth Qld
    Posts
    26
    Why such a complex buck psu when you could just use an 7805 for 5v rail, and an LM317LZ for the other 4V and 3V rails. Assuming the current draw is less than 100mA per reg.
    sPuDd..
  10. #10
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    These devices get damaged much faster with excess voltage, rather than excess current. Try putting a large inductor on the input line to the regulator and put an electro both ends of the inductor.
  11. #11
    Join Date
    Oct 2007
    Location
    England
    Posts
    1,102
    Quote Originally Posted by sPuDd View Post
    sPuDd..
    2 Amp peaks on the 4 V rails.
    1/2 amp continuous on the 5 V rail.
    It can run from 24 V. With a linear regulator I would dissipate 10 W continuous. At the moment, I don't have a heat sink.
    I like Colin55's idea of an inductor, even if I never find the real cause.
  12. #12
    electronica85 Newbie
    Join Date
    Mar 2009
    Posts
    3
    Hi, when you see the smoke, is the IC ZXCL300 loaded or not? Maybe you are over loading it.
  13. #13
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    The first thing I'd try is using a 100n capacitor at the ZXCL300 input and output pins.
    If it oscillates at a very high frequency, which you haven't checked yet it fries to death.
    Boncuk
  14. #14
    mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent
    Join Date
    Oct 2006
    Location
    Hyderabad, India.
    Posts
    2,477
    Blog Entries
    1
    Quote Originally Posted by Diver300 View Post
    Put one 0,1uF cap across input and Gnd of the ZXCL300. Instead, you may also use a conventional TL431 and few components around to get 3.3V or even 3.0V
    Regards,
    Sarma.
  15. #15
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Looking at the Zetex data sheet and the current boost circuit with the ZXCL300 I see a 1µF capacitor each at the input and output pins.
    (I guess they're not there for fun. Zetex obviously knows about the oscillation tendency of that chip.)
    Using two additional 100nF capacitors won't hurt or be astronomically expensive but keep the regulator alife.
    Boncuk
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. studying transistor theory and failing miserably
    By suziebb in forum General Electronics Chat
    Latest: 18th September 2007, 07:35 PM
  2. Lowpass active filter failing at the lower range
    By atferrari in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st July 2007, 12:55 AM
  3. Voltage Regulators!!!
    By PIG80085 in forum Micro Controllers
    Latest: 16th November 2006, 12:17 PM
  4. TV-out circuits on VGA card failing...
    By MrGnome in forum General Electronics Chat
    Latest: 15th January 2005, 05:28 AM
  5. HELP - failing p16pro40 - read 1's
    By jmantilla in forum Micro Controllers
    Latest: 19th August 2004, 07:57 AM
Tags for this Thread
