Old 24th March 2009, 10:05 PM   #1
Default SparkFun LCD what to put into Vee
I just bought the SparkFun LCD:
Graphic LCD 128x64 STN LED Backlight
sku: LCD-00710
I am not sure what to put into Vee from the datasheet. I believe I'm supposed to put in negative voltage like the last LCD I had. I believe it was like -15V but want to make sure. I don't want to fry it.
Link to datasheet:
http://www.sparkfun.com/datasheets/LCD/GDM12864H.pdf
excetara2 is offline
Old 24th March 2009, 10:24 PM   #2
According to the "Electical Absolute Maximum Ratings" table Vee can be between Vdd-19 to Vdd+0.3.
So if you are applying +5V to Vdd, then Vee maximum values are between +5.3V to -14V. According to the "DC Electrical Charcteristics" table typical Vee would be -3V to -12V for Vdd=5V.
Carl
Curmudgeon Elektroniker
crutschow is online now
Old 24th March 2009, 11:23 PM   #3
Many VLCDs have their own -VEE generator, check the datasheet. (You use a 22K pot between +5, VEE & VEE Gen)
Bill
Smart Kits build Smart People
Old 30th March 2009, 09:35 PM   #4
Default Almost
**Sorry, meant to make this a new topic, this has nothing to do with the Vee**
OK, I've narrowed down the problem. Using a logic analyzer, I realized that my ENABLE signal is not being pulsed (I believe it has to go from 1 to 0 for the instruction to be executed). In the code that I downloaded, it has these two lines:
#define LCD_E_HIGH (PORTD |= (1<<5))
#define LCD_E_LOW (PORTD &= ~(1<<5))
Then, to set ENABLE high or low they simple just use
LCD_E_HIGH; or
LCD_E_LOW;
Does anyone see a problem with these? For some reason they are not triggering the enable. Or can someone explain what the first two instructions do?
Thanks again!
Old 31st March 2009, 12:47 PM   #5
The first one says to OR portD with 1 shifted to 10000, the second says to AND it with the complement of 1 shifted to 10000.
This looks way too complicated for a #define compiler instruction. Assign LCD_E_HIGH and LCD_E_LOW to macros that do direct bit manipulation or bit masks.
duffy is offline
lcd, put, sparkfun, vee
Olimex(Sparkfun) LCD Dev Board and 'C' fenderman Micro Controllers 2 19th October 2008 10:39 AM
