Hi guys, I'm working on a project that requires the use of an 4N25 Opto-Iso. I need for the trigger to pull a pin on a 74138 low. Will this circuit work?
__________________ William Estrada MrUmunhum@popdial.com Mt-Umunhum-Wireless.net ( http://64.124.13.3 ) Ymessenger: MrUmunhum | |
Use a resistor going from the pin 5 to +V (or whatever HI voltage is normally on the pin) and connect pin 4 to ground. When the output transistor is off, no current flows in the resistor. No current flow = no voltage drop so both ends of the resistor have the same voltage (+V). WHen the transistor turns on, the pin gets shorted to ground and current flows through the resistor to make a +V-GND voltage drop. You should check the BJT is actually "shorting" the pin to ground by enough though since an opto transistor might not be activated enough in which case you would need to use the opto output transistor to instead power an amplification transistor (which is connected to ground on one end and connected to +V through a resistor on the other end same as before, just with an external transistor rather than with the opto transistor. All that said... I have no idea why your circuit is the way it is. WHat's with the 5VDC? and the two pins on the IC? It appears very incomplete or incorrect. YOu also did not tell us which pin you were trying to pull low.
__________________ Tanaka Sensei (avatar) says: Please spell it "ridiculous" correctly! Not "rediculous". ^^ Last edited by dknguyen; 23rd March 2009 at 09:10 PM. | |
DK, The circuit is not complete. My understanding of electronics is crude. I'm a software guy by training. What I am trying to do is use a 74148 to transform 1 of 8 bits into a BCD representation of that state. Code: 1 => 001 2 => 010 3 => 011 etc. Thanks for your response.
The 74148 is a decoder and does the opposite of what you want, it converts BCD to 1 of 8 outputs. You want an encoder circuit such as the CD40147. On the CD40147: Connect 9 inputs (1 through 9) individually to Gnd (Vss) using nine 10k ohm resistors. Connect input "0" to +5V (Vdd) (this makes the output 0000 when all inputs are "0"). Connect the emitter (pin 4)of each opto isolator to it's respective input 1 through 8. Connect the collectors (pin 5) of all the opto isolators to +5V (Vdd). Make sure there is a resistor in series with each opto input (pin 1) to limit the input current to the desired value. Turning on any of the opt isolators will pull its respective output to +5V (logic 1). The outputs (A,B,C,D) will be the BCD value of the selected input, as you desired.
__________________ Carl Curmudgeon Elektroniker | |
| | #5 | |
Code: 8-input priority encoder 74F148
FUNCTION TABLE
Inputs Outputs
EI I0 I1 I2 I3 I4 I5 I6 I7 GS A0 A1 A2 EO
H X X X X X X X X H H H H H
L H H H H H H H H H H H H L
L X X X X X X X L L L L L H
L X X X X X X L H L H L L H
L X X X X X L H H L L H L H
L X X X X L H H H L H H L H
L X X X L H H H H L L L H H
L X X L H H H H H L H L H H
L X L H H H H H H L L H H H
L L H H H H H H H L H H H H
H = High voltage level
L = Low voltage level
X = Don’t care
__________________ William Estrada MrUmunhum@popdial.com Mt-Umunhum-Wireless.net ( http://64.124.13.3 ) Ymessenger: MrUmunhum | ||
| | #6 |
hi, As you say the 74F148 is an 8 bit to 3 octal encoder.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | |
| | #7 |
| Thanks, just want to make sure I an not losing my mind.
| | #8 |
| hi, Connect the emitter of the 4N25 to 0V, connect a 4k7 resistor from the 4N25 collector to the +5V supply, the junction of the collector and resistor goto the input pin of the 148 ic. The EI pin should be connected to 0V and the EO pin to +V via a 4K7. OK.?
| | #9 |
| Typo? Did you mean a 47K resistor?
| | #10 |
Yes, it's 74F148 is an encoder. Must have somehow been looking at the wrong data sheet.
| | #11 |
| Hi, It just another common way of writing the decimal point, so 4K7 == 4.7K Its a 4.7K resistor you need.
| circuit, iso, opto, work |
| will this circuit work? | strokedmaro | Electronic Projects Design/Ideas/Reviews | 32 | 15th November 2008 07:32 AM |
| Why does this circuit even work? | electronzen | General Electronics Chat | 2 | 28th September 2008 06:44 PM |
| Will this circuit work? | b_reagle | Electronic Projects Design/Ideas/Reviews | 36 | 8th August 2008 08:24 PM |
| Needed - a simple Opto switch circuit | BO NONN | Electronic Projects Design/Ideas/Reviews | 5 | 12th July 2006 05:32 AM |
| Will this circuit work??? | jaxart | Electronic Projects Design/Ideas/Reviews | 0 | 30th August 2004 04:33 PM |
