| I bought a 30 year old trailer to haul a boat. However, all the wires were all corroded. So i ran all new wires. However, when i step on the brakes and have the lights on, the right light is off and the left one lights up. every other function works fine (ie, left turn signal with and without lights and brakes and so forth) any idea what could be causing this? thanks david
__________________ thanks, david | |
| 10 to 1, the right light that goes off has a corroded ground. The extra current of the brake light heats the corrosion and opens the ground, a common problem. Try cleaning the connection, or put in a new bolt.
| excellent, i'll try it tomorow and let you know. sounds very possible as it is all rusty. in the mean time.... i dont really understand how it works.... if you have 2 voltage sources together, isn't that not good? for example, if there are 2 wires running to one side of a light and the other side is grounded, is that ok? cause that seems to be what is happening here when the breaks are hit while the lights are on... 2x 12v is going to the light. that should make it 24v and be twice as bright, correct? thanks
| I'll bet Russ is right, as far as the 24volt question it's not 12x2 it's the same 12 volts,after all you only have one 12 battery . The bulb should have 2 filaments, one for tail light,one for brake/turn signal and is the brighter of the two. Also make sure you have a good ground to your tow vehicle, another common problem.
__________________ gerty | |
| BTW -- Just a point of interest for those out there using older trailers with newer towing vehicles... Most boat/utility trailers use four wires:
Most older vehicles used a single dual-filament lamp for the functions of tail light, stop light, and turn signals. The lower candlepower filament was used for the tail light function, while the brighter filament was used for both turn signal and stop light/hazard functions. Thus, if the driver applied the brakes with the turn signals "off", the current from the stop light switch was routed through the turn signal/hazard switch to both rear lamps. If the brake was applied with the turn signal "on", the stop light current was routed via the turn signal/hazard switch to only the rear lamp on the side opposite the active turn signal. Newer vehicles generally have the stop light and turn signal/hazard functions provided by separate lamps. Thus, the combine/separate function of the turn signal/hazard switch is no longer needed or present. As a result, you end up with five wires from the towing vehicle (r/s turn, l/s turn, tail, stop and ground) instead of four as described above. This leaves you with two alternatives:
Using a converter eliminates the need for additional lamps on the trailer. Converters are commerically available at most trailer and/or boating supply houses. Or... you could build your own using a circuit like this one. I don't recall the original source of this basic design, but I have updated and clarified it, and I have added the standard trailer wire color codes as well. | |
| Ive fixed this type of problem before. As electric current finds steel a bad conductor its better to have an insulated return earth system back to the battery end of problems 8) | |
| I bought a very old trailer also ,I sandblasted it and found it was just easier to replace all the lights and wiring .Might be better for you in the long run .Good luck .ER
__________________ Crusin' Usin' Electric | |
| Three year old thread | |
| oops sorry
