Setting up Solid State Relay to Solenoid with Snubber Circuit
  1. #1
    excetara2 excetara2 is offline
    I am setting up the Sharp ST102T202 solid state relays to the solenoid valves that operate at 120VAC and 10W. The recommended values for the snubber are 47Ohms and .022uF. I found cheap capacitors but what is the cheapest resistors to get because of the high voltage rating. Cheapest I could find were carbon composition for 2 dollars per resistor.
    On page 9 of the datasheet (http://www.electro-tech-online.com/c.../s102t02_e.pdf) is the setup we are using.
    Thanks.
  2. #2
    i_build_stuff i_build_stuff is offline
    The resistor can actually be a lot smaller than that--maybe like a 1/2 watt or so.
    A 0.022uF capacitor will have a reactive impedance of about 120k ohms, so you're really only looking at about a milliamp of current when the thing is on. At turn off, there will be a spike of power that might get into the hundreds of watts, but it only lasts for like a microsecond, so the resistor doesn't need much of a rating.
    If you want a pre-packaged solution, you could always go with a Quencharc. These ones might be a bit overkill for your application, but they are convenient and will definitely protect your SSR:
    CORNELL DUBILIER|104M06QC100|Film Capacitor | Newark.com
    For the cheapest option (assuming you have a lot of solenoids, and that's why you bring it up), I would go with 24VDC solenoids. Then, you only need a diode across the coil, and a transistor for drive it (instead of that SSR).
    0
DIY SSR (Solid State Relay) ??? Can I ??? RogerTango General Electronics Chat 6 31st December 2008, 10:13 PM
Solid State Relay ahmedragia21 General Electronics Chat 8 1st July 2008, 12:09 AM
Solid State Relay madcitysw General Electronics Chat 19 30th April 2008, 09:33 PM
solid state relay mhtavallaie Electronic Projects Design/Ideas/Reviews 3 15th February 2005, 12:01 PM
Solid State Relay Help bryan Electronic Projects Design/Ideas/Reviews 2 25th June 2003, 08:17 AM
Page Time: 0.05697 seconds      Memory: 7,401 KB      Queries: 16      Templates: 0
