+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 18
Thread: Using a PLC to contorl/simulate the use of a washing machine
  1. #1
    pablome Newbie
    Join Date
    Feb 2007
    Posts
    72
    Default Using a PLC to contorl/simulate the use of a washing machine
    I was wondering if its possible to take apart the washing machine and have the motor, buttons or whatever else controlled by the plc as a project.
    If there is a controller ill just replace it with the PLC.
    I wont keep the tub and agitator, just want to control like valves, or a pump, the motor.
    However I want to figure out or get suggestions on how to control the motor if im just gotta use a digital In/Out PLC....using thresholds or how?
  2. #2
    pablome Newbie
    Join Date
    Feb 2007
    Posts
    72
    bump bump bump
  3. #3
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,285
    Blog Entries
    2
    Didnt we cover this already?
    Check out bb-elec.com
    Download the free PLR software. Design it with that. It will give you the ability to use basic switch inputs and relay outputs to run everything.
    Now do the rest of your homework yourself!
  4. #4
    pablome Newbie
    Join Date
    Feb 2007
    Posts
    72
    The software to program these PLC is free? and windows compatible..
  5. #5
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    Quote Originally Posted by pablome View Post
    It is? Which software?
    Bill
    Smart Kits build Smart People
  6. #6
    picbits Excellent picbits Excellent picbits Excellent picbits Excellent picbits Excellent
    Join Date
    Jan 2007
    Location
    Northants, United Kingdom
    Posts
    1,160
    Theoretically making a washing machine driver is a piece of cake.
    In practice its an absolute nightmare. Most things are easy until you hit the speed control for the main drum.
    Trying to keep a constant speed for a drum full of wet washing is not an easy task. You have 7kg+ of unbalanced wet clothes that need rotating at a perfect speed or they will stick to the sides of the drum. You also need to balance the clothes before spinning of your washing machine will shake itself to bits.
    I'm speaking from personal experience. I designed a PIC controlled washing machine with a RS232 interface to my PC running software that was nicknamed "Winwash 2000"
  7. #7
    Join Date
    Feb 2009
    Location
    Posts
    3,285
    Blog Entries
    2
    I know I coverd this on the PLC home security thread.
    bb-elec.com PLR programming software is free and easy to use.
    program and simulator software are simple and user freindly.
    check it out I use it all the time.
    Blaa blaa blaa blaa
    Do some of you smoke pot, then go online?
    PS. You do actualy have to go to Google and type in, bb-elec.com
    I am not going to link it for you.
  8. #8
    pablome Newbie
    Join Date
    Feb 2007
    Posts
    72
    Quote Originally Posted by picbits View Post
    Why is it gona be a nightmare trying to keep the constant speed of the drum? Forget the clothes for now.
    Can you actually help on what sort of circuitry with the PLC or what PLC I should be expected to work with or use. I mean interfacing.
    I got a schematic or so of a little one...check it.
  9. #9
    Join Date
    Jan 2007
    Location
    Posts
    1,160
    Getting a constant speed on the drum is a piece of cake (dont forget you get front loading machines as well as top loading).
    As soon as you put clothes in it, it becomes more difficult. When the clothes are wet it becomes very difficult and you need a fine tuned closed loop system with a very fast response time.
    If you don't believe me try it for yourself.
    P.s. Pablome - how would you suggest controlling the speed of an inductor motor commonly used on washing machines ?
  10. #10
    Join Date
    Jan 2007
    Location
    Posts
    1,160
    And if you asked for a "Washing Machine" in the UK, this is generally what you'd end up getting ......
  11. #11
    pablome Newbie
    Join Date
    Feb 2007
    Posts
    72
    i guess control the voltage or frequency, have either a tach encoder for feedback or some closed loop.
    Is front load easier to control than top load.....im gona use that top load.
  12. #12
    Join Date
    Jan 2007
    Location
    Posts
    1,160
    Top load looks far easier to control than front load.
  13. #13
    pablome Newbie
    Join Date
    Feb 2007
    Posts
    72
    oh okay. but can you help me explain from that circuit what added circuits or components might be needed to contrl this without the "program control unit" card (i havnt checked inside yet) but with plc. THeres like 10 inputs perhaps. some outputs.
  14. #14
    Join Date
    Jan 2007
    Location
    Posts
    1,160
    That isn't a circuit, its a wiring diagram.
    I won't go into detail with the circuits I used as they were PIC based and not PLC which is what you're asking for.
  15. #15
    Join Date
    Feb 2009
    Location
    Posts
    3,285
    Blog Entries
    2
    To control the speed of a motor its easier to just use a factory made VFD unit. most have 0 -10 volt inputs that translate that right to the programed frequency range.
    Or use a two speed motor like most standard machines use around here.
    3 differnent VFD specs included. All of these VFD units I purchased on ebay for less than $30 each.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Washing machine motor...
    By brentonw2004 in forum General Electronics Chat
    Latest: 31st December 2009, 07:31 PM
  2. controller for washing machine
    By wahyutri in forum General Electronics Chat
    Latest: 1st December 2008, 10:39 PM
  3. Washing Machine
    By febo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th May 2007, 09:50 AM
  4. washing machine
    By larva in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd April 2007, 08:54 PM
  5. washing machine controlling
    By mahinda jayasingh in forum Micro Controllers
    Latest: 4th March 2004, 04:09 AM
Tags for this Thread
