I need hifi audio isolation circuit, using without audio isolation transformer for my tv set to connect hifi system. with out this circuit may i shock with high voltage to touch metal body of hifi system or ground line, speaker terminals or input jacks. A good quality audio transformer is not chip or not small in size. any body can give me an idea to make this circuit? | |
Just use a capacitor in each line. Pick any value you like such as 100n and put a resistor or a pot across the input (after the caps) to adjust the audio level. Use 200v or higher for each cap. | |
| | #3 | |
Thanks for idea, but caps are not electrically isolate the audio signals.at first i make a circuit with your idea but it do not isolate high voltage.
If you put 4k7 resistors on each input line to ground, the resulting voltage on the input will be less than 10v.
| | #6 |
Is ok, but with respect of earth it always 220 voltage ac but not direct, its voltage drop some kilo Ohms loads. i am sure it is not leakage voltage. My tv set circuit supply voltage is not isolate then mains
| | #7 |
It does not matter if your TV is "live" or not. If you put the resistors on the input to your amplifier and earth the amplifier, you will not see any voltage on the input of the amplifier. | |
| | #8 |
Yes!! thanks of lots, my problem is solve. i put a connection my signal ground and earthing and also surprise my sound quality is far far better then previous,
| audio, hifi, isolation, transformer |
| Audio ground isolation | lasvegasmale31 | Electronic Projects Design/Ideas/Reviews | 2 | 16th January 2009 06:58 PM |
| Tripp Lite Isolation transformer *not* an isolation transformer | speakerguy79 | General Electronics Chat | 31 | 13th September 2008 11:14 AM |
| Need Help : Audio Transformer and PIC | Engeocer | General Electronics Chat | 12 | 26th March 2007 12:45 AM |
| Audio transformer | crivoli | Electronic Projects Design/Ideas/Reviews | 8 | 7th May 2006 08:11 PM |
| Audio Transformer (help) | Clyd3 | Electronic Projects Design/Ideas/Reviews | 1 | 27th September 2003 05:54 PM |
