Hey all, newbie to the forum here.
I am working on a product and am looking for some advice. I've used PIC 16 series chips a good deal and an looking to move up to the 18 series, specifically the 18F452 because I believe the 16bit core plus higher speed could be valuable to my product. What I am after is an in circuit programmer for these chips. I am using a Maxim MAX662 flash voltage generator to program 16F877 and the like. I was hoping it would be easy to migrate this technique to the 18 series. Can anyone offer me some advice? Thanks 8) |
Using a MAX662 seems a very difficult way of doing in-circuit programming, a simple serial interface can be used for a bootloader, the 16F877 supports this, and (as far as I know) so do most of the 18 series chips. It also provides you with a serial port, which can be used elsewhere in your application. |
In the past I have used PP18
http://perso.wanadoo.fr/softelec/Pro...P18_WIN_us.htm Works great, his schaer programer design works great to, just use good transistors. Have fun Kent |
There are plenty of PIC18 bootloaders. Just do a web search for "PIC18 bootloader"
The PIC18 has a multiplication op that handles 16 bit numbers. I don't believe it can properly be called a 16 bit core, however. I like the speed & size of the PIC18F 252/452. I do everything in HiTech PIC-C; the expanded command set in the 18 series is supposed to work better with C though I have no way to verify this. I expect that taking advantage of the expanded command set when programming in assembly will require additional learning time. I believe the PIC16 commands are still all there, though. |
It's still an 8 bit processor though!, as are the 14 bit and 12 bit cores. |
