+ Reply to Thread
Results 1 to 11 of 11
Thread: Rds(on) of mosfet.
  1. #1
    Banned alphadog Bad
    Join Date
    Feb 2009
    Posts
    236
    Default Rds(on) of mosfet.
    I read in a datasheet of mosfet that its Rds(on) 1.35ohm @ VGS=10V, IDS = 2.7A.
    When in ON state, is IDS = VDS / RDS(on) ?
    Thank you.
  2. #2
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Basically, yes. VDS should be fairly low at that point and IDS should be within spec and limited by the design of the circuit.
  3. #3
    Banned alphadog Bad
    Join Date
    Feb 2009
    Posts
    236
    Thanks.
    Correct me please if i'm wrong, in saturation state, Rds is very large, then how come IDS is maximal (for constant VGS) in sturation state?
  4. #4
    ronsimpson Good ronsimpson Good ronsimpson Good
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    710
    In saturation state RDS is very small.
  5. #5
    Banned alphadog Bad
    Join Date
    Feb 2009
    Posts
    236
    But in stauration state, Rds = VA / IDS, isnt it?
    And VA (Early Effect Voltage) is very large, therefore Rds is very large also.
    Where am i wrong?
  6. #6
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    710
    The numbers from a data sheet do not mean the FET will all wise work like that.
    In your example from the first post: 10 volts is applies from G-S. A current source (2.7A) is applies to the D. The FET looks like a 1.35 ohm resistor. The voltage D-S is 3.6 volts, under these conditions.
    Appling 10 volts to the gate will not cause 2.7 amps. It will cause the FET to turn on and look much like a 1.35 volt resistor. The current is a function of what is on the D.
    Early Effect Voltage???? Are you talking about the first nano-seconds of turn on? Saturation is talking about being on (DC) not AC.
  7. #7
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by ronsimpson View Post
    This is a common misconception for people who cut their teeth on BJTs. Saturation in a MOSFET is basically opposite of that in a BJT. In a MOSFET, saturation is the high-impedance region (active mode) of the characteristic curves.
    Ron
  8. #8
    Chaerl Newbie
    Join Date
    Feb 2009
    Location
    Ireland
    Posts
    59
    I know the early effect voltage (VA) is normally applied with BJT's. I don't know if it is applicable with FET's. It is actually the variation of the width of the base as the reverse voltage between collector base varies. Typically, the gate of the FET's as virtually isolated, high impedance input.
  9. #9
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,721
    Quote Originally Posted by Chaerl View Post
    A search finds several references to the Early effect in MOSFETs. It's a different effect, but with similar results.
    Ron
  10. #10
    Chaerl Newbie
    Join Date
    Feb 2009
    Location
    Ireland
    Posts
    59
    Quote Originally Posted by Roff View Post
    I see, I try to dig on that for more details.
  11. #11
    Banned alphadog Bad
    Join Date
    Feb 2009
    Posts
    236
    similar to the way the VA describes the linear dependency of IC on VCE in saturation region in BJT, it also describes the linear dependency of IDS on VDS in saturation region in MOSFET.
+ Reply to Thread
  1. Need help with PWM mosfet
    By smilem in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th November 2009, 08:48 PM
  2. MOSFET Vgs
    By dark in forum General Electronics Chat
    Latest: 25th December 2008, 07:10 PM
  3. Mosfet Help
    By NickLee in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th December 2008, 01:00 AM
  4. Mosfet to ground or mosfet from +v?
    By bh00 in forum General Electronics Chat
    Latest: 23rd May 2006, 06:42 PM
  5. Why use MOSFET instead of BJT?
    By StupidDum in forum General Electronics Chat
    Latest: 3rd December 2004, 06:56 PM
Tags for this Thread
