+ Reply to Thread
Results 1 to 2 of 2
Thread: Lowpass filter for ADC
  1. #1
    tuanvoi Newbie
    Join Date
    Jan 2009
    Posts
    40
    Default Lowpass filter for ADC
    Hi all,
    Could you please confirm that for a digital signal(this signal was ADC from analog voice signal), if I want to convert this digital signal back to analog, do I need to use a lowpass filter or any kind of filter to get the analog one and what range of the LPF? Thank you
    Tom
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,832
    Men's voices go lower than 200Hz and consonants sounds in speech go much higher than only 3400Hz.
    An ADC produces a stepped digital output that is full of harmonics. You can hear the harmonics as high frequency buzzing sounds so they must be filtered out.
    A CD player has a 44.1kHz sampling rate and a very sharp lowpass filter that attenuates everything above 22kHz.
+ Reply to Thread
  1. Lowpass active filter failing at the lower range
    By atferrari in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st July 2007, 12:55 AM
  2. Lowpass xover with gain and Linkwitz Transform.Gain question
    By mikee55 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th January 2006, 09:44 PM
  3. Filter ,a band pass filter working around 20khz
    By santosh_iitm2002 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd September 2004, 04:31 PM
  4. Lowpass Filters
    By Typhoon in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st September 2003, 03:42 AM
  5. Bandpass Filter for a Vocoder?high order filter??? advice!!!
    By damenace in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th June 2003, 08:59 AM
Tags for this Thread
