+ Reply to Thread
Results 1 to 11 of 11
Thread: 120V AC to 12V DC
  1. #1
    sammy004 Excellent sammy004 Excellent sammy004 Excellent sammy004 Excellent
    Join Date
    Jan 2004
    Location
    Olympic Champions Canada
    Posts
    105
    Default 120V AC to 12V DC
    Hi guys I just wanted to know if anyone knows of a good and cheap way of building a 120v AC to 12v DC converter. I want just a small one to run a pair of LED like these.
    Here
    I found a schematic here Here but it looks quite heavy duty. I am just looking for a small one and cheap to build, can anyone help me on this please.
    Thank You
    Sammy
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    Just buy a wall adapter.
    Bill
    Smart Kits build Smart People
  3. #3
    BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent BeeBop Excellent
    Join Date
    Dec 2005
    Location
    Vancouver Canada
    Posts
    1,192
    Quote Originally Posted by sammy004 View Post
    Here
    Thank You
    Sammy
    The link you posted is for a 12VDC to 120 VAC inverter, not what you wanted!
    The cheapest and simplest way, would be to walk into a thrift store and buy a wall wart which may cost a dollar or so.
    You could build one with a 120V - 12V transformer, rectifier, a LM7812 regulator and a couple of caps. Your cost would be about 20 bux or so...
    All that typing, and Bill beat me with a simple line.
  4. #4
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,708
    Blog Entries
    5
    LOL and any cheap wall adapter can run a couple of LEDs
    Bill
  5. #5
    Diver300 Excellent Diver300 Excellent Diver300 Excellent Diver300 Excellent
    Join Date
    Oct 2007
    Location
    England
    Posts
    1,096
    That circuit that you found is for going the opposite way to what you want.
    You want a 12 V power supply rated at 3 A or more, if you are running two of those. (The data sheet says 1.5 A max).
    PYRAMID POWER SUPPLY:PYRAMID 12 VOLT REGULATED DC POWER SUPPLY PS4KX would be fine.
    Igloo Kool Mate Universal 120v Adapter - Toys "R" Us is a switch-mode design and will be a lot lighter.
  6. #6
    Join Date
    Jan 2004
    Location
    Posts
    105
    Thanks guys for the great advice I will try to look for a wall plug.
  7. #7
    JBrock Newbie
    Join Date
    Feb 2009
    Location
    Carlsbad CA
    Posts
    46
    Exclamation As you may know...
    Make sure the wall adapter is DC output, and be careful to get the polarity (+/-) right!
  8. #8
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,859
    Quote Originally Posted by BeeBop View Post
    And it is one that DOES NOT WORK.
    The polarity of its capacitors is backwards so they blow up.
    The emitter-base diodes of the transistors have avalanche breakdown so the capacitors also blow up even if their polarity is corrected.
    The base current of the transistors is way too low for an inverter.
    Its output is about 50V at 25W.
  9. #9
    duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    You're good. That base-emitter junction can only handle about -7V or so, and those polarized caps are backwards at best. You work with that circuit before?
    How about this... add a pair of base-emitter diodes and flip the caps around. Diodes in reverse to the base-emitter junction work like a charge-pump, protect the base and the caps from inverse voltage, increase the average charge to drive those unimpressive 2N3055's to higher wattage.
  10. #10
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,859
    Quote Originally Posted by duffy View Post
    I saw the circuit at electronics-lab but the original is at aaroncake.net. Aaron has two very long threads about how guys tried many things to make it work but nobody did.
    A simple square-wave inverter needs a half-decent oscillator like a CD4047 then some paralled output transistor for high current.
    A CD4047 probably won't drive Mosfets properly because its outputs do not have any dead time, they switch at exactly the same time. One Mosfet turns on when the other is still turning off and the shoot-through current will be too high.
    On Aaron Cake's site we discussed a modified sine-wave inverter (actually a modified square-wave) with PWM for voltage regulation.
  11. #11
    frosty Bad
    Join Date
    Nov 2008
    Location
    L.A calif.
    Posts
    42
    Default 115v to 12vdc
    Hi all, I am looking to build a pwm for a hydrogen unit with 3 cells, the input needs to be 115v ac input and the dc for the pwm hookup for the unit it will draw about 3 amps.
+ Reply to Thread
  1. 120v 60hz to 9v 50hz
    By dondo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd February 2008, 11:57 PM
  2. Will this work with 120v?
    By Andy1845c in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th November 2006, 09:48 PM
  3. 120V dimming
    By MrMikey83 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th August 2005, 01:50 AM
  4. 120v A/C Indicator help
    By Jerry D in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th November 2003, 07:48 PM
  5. 120v AC to 12v DC
    By dunndeal in forum General Electronics Chat
    Latest: 1st November 2003, 05:28 PM
Tags for this Thread
