+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 30
Thread: Some help needed to build my zapper
  1. #1
    Splash1 Newbie
    Join Date
    Dec 2008
    Posts
    15
    Hi everyone,
    I want to build a Zapper (Dra Hulda Clark Zapper). This device is usefull to zap ourselves to kill parasites, some bacterium, etc...
    This device is very simple, because you need a battery, the circuit and 2 copper pipes (one in each hand) and switch on the device, to get the 30 KHz square wave, POSITIVE offset. (What is Positive Offset?)
    The circuit is very simple:
    I have all the parts, but I don't know how to build it.
    I have 2 kind of resistors:
    * Orange, White, Red, Golden
    * Brown, Black, Orange, Golden
    The background of the second resistance is dark red colour instead of the common 'yellow' colour.
    I also want to use a wall transformer instead of a 9 Volt battery. My wall transformer output is 9 or 9.5 Volts, 550 mAmps..
    The man of the shop has give me a NE555N, instead the LMC 555 CMOS timer chip that the book says. Can I use the NE555N?
    I don't need to solder because I have a white board where you can connect directly the components.
  2. #2
    iflymyhelishigh Newbie
    Join Date
    Oct 2008
    Location
    Northern VA
    Posts
    79
    Quote Originally Posted by Splash1 View Post
    Hi everyone,
    I'm pretty sure Brown Black Orange Golden is a 1K resistor, and Orange White Red Golden is a 3.9 K resistor.
    Just stick with a 9 volt battery just in case.
    I am pretty sure that the NE555N will work. Let me do some research.
    Your white board is called a bread board. Be careful with that, if it somehow urns through, you might screw your components.
  3. #3
    RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent
    Join Date
    Oct 2005
    Location
    BC, Canada
    Posts
    1,447
    Blog Entries
    1
    Yes, the NE555 should work the same as the LMC555. The main difference between the two is that the LMC555 draws less current from your battery, so when using the NE555, you should expect your battery to last a shorter time than if using the LMC555. Even so, the battery should still last about 100 hours or more.
    The Orange White Red Golden resistor is 3.9K ohms.
    If the second resistor is brown black orange golden, then it is a 10K ohm resistor. But your circuit requires a 1K ohm resistor which should be brown black red golden. Have another look at that resistor and see if you have made a mistake in the colour and perhaps the third band is indeed red. The background colour may be altering the red band to make it look a bit orange. This can be checked using an ohmmeter if you have one.
    DO NOT USE A WALL TRANSFORMER. For safety reasons, you should not use a wall transformer for this device. There is a danger of electrocution. I strongly recommend that you use the 9V battery instead.
    To build the circuit, you need to understand how the conductors in the white plug board are arranged. You will be plugging your parts into that board making connections that match the schematic diagram.
    Here is a link showing the white board:
    Using Solderless Breadboard - Mechatronics Wiki
    RadioRon
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,291
    Are you crazy?
    Zapping yourself will not get rid of parasites and bacteria.
    Why do you believe those lies? The government does not believe them.
    The circuit is a simple oscillator with an output of only 9V with an LMC555 IC and an output of only 7.5V with an NE555. You, the parasites and the bacteria won't feel it and won't be affected by it. You need thousands of volts to be zapped.
  5. #5
    Splash1 Newbie
    Join Date
    Dec 2008
    Posts
    15
    I'm looking better at the resistor and it looks like orange. Brown, Black, Orange and Golden. Maybe the background color is altering the red band... because I can say if the band is red or orange. It's a mixed colour.
    I have a multimeter, can I test the resistor with a multimeter? How?
    Yes, I have that, a breadboard! Thanks!
  6. #6
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,291
    Set the multimeter to read ohms and measure the resistors away from the circuit.
  7. #7
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,666
    Quote Originally Posted by audioguru View Post
    Are you crazy?
    Oh ye of little faith!
    Ron
  8. #8
    Splash1 Newbie
    Join Date
    Dec 2008
    Posts
    15
    We're discussing about electronics, and not about biology. I will see if that is true or not. But I want to build the device.
  9. #9
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,291
    The device is just a simple low voltage oscillator.
    It will have no effect on biology.
    I am not the only person not believing this crap.
    Texas AIDS Blog: Parazapper zapped by FDA
  10. #10
    jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    Build the device. But for once, I agree with audioguru. You are a fool, if you think it will work, particularly if you think it will kill bacteria.
    John
  11. #11
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,291
    Parasites? Like dragons? Lizards?
    Then simply stop eating them and they will be gone.
  12. #12
    4um Addict Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent
    Join Date
    Jan 2009
    Location
    Toledo, Ohio
    Posts
    832
    And we certainly are not talking about sanity either...
    But the question begs to be asked "what do you do with the probes?"
  13. #13
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,291
    Quote Originally Posted by mike2545 View Post
    Place the probes "where the sun doesn't shine".
  14. #14
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    I suspect the circuit and pictures are missing a step up transformer needed to make it into a zapper, probably a cheap 10k:8 ohm audio transformer wired backwards.
    Lefty
    Measurement changes behavior
  15. #15
    Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent Mikebits Excellent
    Join Date
    May 2008
    Location
    San Diego, Ca
    Posts
    3,842
    Blog Entries
    2
    If it were to kill bacteria in the body which it won't, then you would be killing bacteria that provide a mutualistic symbiotic relationship with its host. In other words, you would be killing helpful bacteria that your body needs. But by all means, zap away...
    Pay it forward.
    www.geoepicenter.com
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Battery zapper
    By EADracer in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th October 2008, 04:19 AM
  2. Electric bug zapper
    By drakeeclipse in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th August 2008, 05:49 AM
  3. Rat-Zapper?
    By HarveyH42 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th June 2008, 12:15 AM
  4. Error During Build-- Help needed. PIC.
    By Ayne in forum Micro Controllers
    Latest: 23rd December 2006, 09:08 AM
  5. SHARK zapper
    By FrogMan in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th October 2002, 11:11 PM
Tags for this Thread
