+ Reply to Thread
Results 1 to 7 of 7
Thread: binary to 7 segment problem
  1. #1
    mizort1989 Newbie
    Join Date
    Feb 2009
    Posts
    3
    Default binary to 7 segment problem
    hi guys
    i am designing a 4 bit alu with 64 bit ram and i have a problem displaying the output of the alu
    it works fine with 4 leds (i only have numbers up to 15) 4 bit
    i want to display the o/p on a 7segment display
    so i can use 7447 or 4511 but i can only disanceplay on it numbers from 0-->9
    coz its bcd so how i can cascade it to display 2 digit number (10 11 12 13 14 15)
    thanks in adv
  2. #2
    mizort1989 Newbie
    Join Date
    Feb 2009
    Posts
    3
    please note that i cant use eprom or pic or microprocessor
  3. #3
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,672
    Blog Entries
    5
    What kind of microcontroller can you use? AVR?
    Bill
    Smart Kits build Smart People
  4. #4
    duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    If you can lay your hands on a couple of TIL311 displays, that would do it. They had 4-bit inputs, latch, decoder, driver and display all together. The display was hexadecimal, so all you codes are covered.
    Device is obsolete, but I saw a few sites on the net looked like they might have some left in stock.
  5. #5
    mizort1989 Newbie
    Join Date
    Feb 2009
    Posts
    3
    please guys help me i need a solution to my problem
    i cant find this TIL311 displays you told me about
    is there any way to cascade 4511 or 7447 ic to display to two digit number
    from 4 bit binary input
  6. #6
    arhi Excellent arhi Excellent arhi Excellent arhi Excellent arhi Excellent arhi Excellent
    Join Date
    Apr 2008
    Location
    Belgrade, .rs
    Posts
    832
    DM74185A - check the attached datasheet - is a 6bit binary to bcd converter.
    place it between output of your ALU and bcd 2 7seg drivers
    hope that helps
    EDIT: you can do it with only one bcd 2 7 seg as first digit is only 0 or 1 hence you can connect the pin Y4 (MSD-A) directly to segments that make "1" on first digit and Y1-Y3 to BCD input of bcd to 7seg (A input on bcd 2 7seg is lsb from your alu) so you will get "blank" first digit for 0-9 and 1 will light for 10-15 ... clear ?
  7. #7
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    Guy on eBay is selling TIL311's for eight bucks a pop. Says he has more than 10 in stock -
    TI Texas Instruments TIL311 Intelligent LED Display - eBay (item 310123443095 end time Mar-19-09 12:52:17 PDT)
+ Reply to Thread
  1. Converying binary to 7-segment (decimal)
    By zanes in forum General Electronics Chat
    Latest: 2nd April 2008, 08:46 PM
  2. Binary input Hex dispaly (7 segment LED)?
    By dalmation in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th November 2007, 01:10 PM
  3. 24H 7-segment binary clock
    By spitfire in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th September 2007, 09:40 AM
  4. 8 / 10 / 14 bit Binary to 7 segment display help
    By regomodo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th May 2007, 11:27 PM
  5. 7 Bit binary to Decimal on two 7-segment display.
    By Dagon in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th February 2005, 10:36 PM
Tags for this Thread
