If we the voltage waveforms of an inductor and the source voltage, its clear that the inductor voltage leads the source voltage. When does the voltage across the inductor starts reducing???? It reduces when it starts discharging. And when can it discharge??? Only when the supply voltage is lower than the inductor voltage. But if we see the wave forms, the inductor voltage is reducing even when the supply voltage is comparitively above and increasing.. How is it possible???? Please refer to the waveform diagram I have attached. Thankyou. | |
Hi, an inductor is only a temporarily charging device. As soon as the supply voltage decreases - no matter what the inductor's voltage is - the inductor will "discharge" by changing the magnetic field, thereby producing voltage itself. Observe the current flow as well. It has a phase shift of 90deg compared with the voltage. Boncuk
| | #3 | |
An inductor is like a rock. On a rollerskate. You give it a shove, and at first it doesn't move, then it gets going, then it wants to keep going even when you are pulling it backwards. Quote:
| | #4 | |
Hi, You asked this question in another thread and i gave you this answer: Quote:
That's a good question really, as the inductor voltage would lead which looks a little strange at first, but only if you think of the inductor as completely 'passive'. The inductor is considered passive in some types calculations, but for this kind of question the inductor has to be thought of as an energy storage element, which is capable of delivering energy as well as receiving it. It's when the inductor is delivering energy that we see that it is definitely not passive, but active in that it can supply current and voltage to a circuit just like a battery would, at least once it has some energy stored in it. The cap does this too, only it expels its energy in the form of a current, while the inductor does so in the form of a voltage most basically, as when it is trying to maintain a constant current it forces the voltage to some value to satisfy this condition. We could also look at the cap current and ask a few questions too. To best understand the inductor over time we have to look at this little equation: v=L*di/dt where v is the voltage across the inductor L is the inductance value di is the change in current over time increment dt dt is the change in time. Note one thing here: that the voltage (which the waveform shows) depends not on the supply excitation voltage, but the value of the inductance L and the rate of change of the current di/dt. Thus, it is the rate of change of current that determines the voltage, not the supply voltage by itself. What this means is that if you draw the current wave and then look at the inductor voltage wave and think about the derivative of the current wave you will see the inductor voltage follow this relationship. Where the peaks of the current are flat the derivative is zero, so the voltage will pass through zero at those points, and where the current wave is changing the fastest, the current will reach its peaks. Another way is to simply plot the derivative of the current, multiply by the inductance L, and there you have the exact voltage wave. Oh yeah, BTW, it's unfortunate that some fonts render an upper case "i" as l as well as lower case "L", but with a better font this is my screen name: Code: MrAl Code: MRAL | ||
First of all forget the sine wave. Connect the inductor to a DC supply in series with a resistor. Watch the voltage and current across the inductor. When you first connect the power the voltage will be equal to the supply and the current will be zero. As the inductor magnetises the current will rise to what the resistor permits and the voltage across the inductor will fall to zero. The same is true for an AC wavefrom, if the inductor is perfect the voltage will lead the current by 90° and the power dissipated in the inductor will be zero.
| inductor, leads, source, voltage |
| Voltage controlled current source | Analog2008 | Electronic Projects Design/Ideas/Reviews | 2 | 2nd January 2009 08:54 AM |
| What is source breakdown voltage? | b_reagle | Electronic Theory | 8 | 8th September 2008 12:02 PM |
| single voltage source equivalent of multiple voltage sources | sstimuluss | General Electronics Chat | 29 | 31st January 2007 10:33 PM |
| Voltage across inductor | elec123 | General Electronics Chat | 3 | 9th December 2005 04:44 PM |
| voltage and current source | Gaston | General Electronics Chat | 14 | 8th March 2005 06:46 AM |
