+ Reply to Thread
Results 1 to 3 of 3
Thread: virtual Ground question
  1. #1
    Scarr Newbie
    Join Date
    Jul 2003
    Posts
    232
    Default virtual Ground question
    Got a project that is a comm's sniffer / injector, project works fine however it needs two connections to work i.e. GND and test point as you would expect.
    I had a thought and it's only a thought so no flames please, is it possible to only use one connection without having to find a common ground (by a wire that is) I saw mention of "virtual ground" not sure if this is what I'm talking about as it's all a bit heavy reading.
    So question is, to pull a line high / low do I really need a wire connctingh to the GND on target?
    Steve
  2. #2
    flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent
    Join Date
    Oct 2008
    Location
    Amsterdam
    Posts
    557
    To inject an AC signal without accuracy it may work.
    For DC, no.
    For AC, you could use a capacitor from the ground lead to true ground to provide some isolation.
  3. #3
    chrisjpitt Newbie
    Join Date
    Aug 2008
    Posts
    16
    Quote Originally Posted by Scarr View Post
    No, not really - "virtual ground" usually refers to generating a reference point between two supply lines (that is then used as the common or ground for a circuit). It is useful when trying to eliminate ground loops, or hum in AF circuits.
    As flat5 mentions, if the signal was AC or RF, you could use stray ground capacitance to provide a coupling in to the circuit under test (depending on circuit impedances) - but DC really does require something to reference it against.
+ Reply to Thread
  1. Voltage across pin and ground question
    By jasonbe in forum Micro Controllers
    Latest: 18th October 2008, 12:46 AM
  2. What is Chassis Ground, Technical Ground, Circuit Ground?
    By victor in forum General Electronics Chat
    Latest: 11th October 2008, 12:42 PM
  3. A question about Windows Virtual Memory
    By HiTech in forum Chit-Chat
    Latest: 13th December 2007, 04:09 PM
  4. explanation required(virtual ground)
    By konzen in forum General Electronics Chat
    Latest: 31st August 2007, 11:07 PM
  5. OP AMP : Virtual Ground and feedback.
    By lord loh. in forum General Electronics Chat
    Latest: 5th August 2005, 05:07 PM
Tags for this Thread
