+ Reply to Thread
Results 1 to 6 of 6
Thread: Amplifer Help
  1. #1
    Powzoom Newbie
    Join Date
    Dec 2008
    Posts
    24
    Default Amplifer Help
    I've been trying to learn how to design amplifiers with BJTs but I cant seem to figure this out. I have a BJT biased with a voltage divider. I know Vcc = 9V and Vin = sin wave with 1V peak. Beta min = 100. How can I achieve a voltage gain of about 5? Can someone take me through the calculation steps because I've looked everywhere and can't seem to figure it out.
    Thanks.
  2. #2
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    2,946
    If you remove the emitter bypass capacitor C1, then the voltage gain of the stage would be approximately R3/R4.
    Carl
    Curmudgeon Elektroniker
  3. #3
    steveB Newbie
    Join Date
    Jan 2009
    Location
    USA
    Posts
    86
    Quote Originally Posted by crutschow View Post
    That would seem to be good advice. Since the gain is low (5), it can be achieved without the emitter bypass capacitor. This would also reduce distortion. The arrangement shown is typically used for larger gain.
    We can also note that the effective collector resistor Rc is R3 in parallel with the load resistance RL, once the output is hooked up to something.
    Av=-Rc/R4 where Rc=R3*RL/(R3+RL)
    This approximate formula requires that R4 be much greater than hib=Vt/Icq (Vt=KT/q which is about 25 mV at room temperature)
    Of course, the circuit must be properly biased to allow full signal swing and stability to temperature changes, as well as insensitivity to beta changes. Just looking quickly, it appears that the 9VDC power supply will not allow full signal swing with 2V p-p input voltage and a gain of 5.
    It's really difficult to explain all aspects to transistor circuit design in a forum. There are many textbooks on the subject. For example, I used Electronics Design by Savant, Roden and Carpenter back in school. Looking back at it now, it seems to be a good book to learn from. I'm sure other people can recommend good books.
  4. #4
    flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent
    Join Date
    Oct 2008
    Location
    Amsterdam
    Posts
    557
    Here's something for free.
    A PDF file with lots of math.
    http://aries.ucsd.edu/NAJMABADI/CLAS...NOTES/BJT3.pdf
  5. #5
    Powzoom Newbie
    Join Date
    Dec 2008
    Posts
    24
    I follow what you're saying. I just need lots of practice with transistors. It seems like the more I read about them, the less I know about them...
  6. #6
    colin mac Good colin mac Good colin mac Good colin mac Good
    Join Date
    Jun 2007
    Location
    Ireland
    Posts
    342
    See this.
    Worked Example
    It's from "the art of electronics student manual".
    It's all explained in that book if you can get it.
    edit - not the student manual, the full book I mean.
+ Reply to Thread
  1. Current Calculation for Audio Amplifer
    By mike poon in forum General Electronics Chat
    Latest: 22nd December 2005, 06:06 PM
  2. operational amplifer course
    By 4electros in forum General Electronics Chat
    Latest: 4th November 2005, 05:55 PM
  3. Power Amplifer needed
    By gb in forum Electronic Projects Design/Ideas/Reviews
    Latest: 26th September 2005, 02:24 PM
  4. Need help with a 500w to 600w amplifer
    By Roboticinfo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th June 2005, 03:41 PM
  5. 20 watt amplifer IC
    By Earthshaker in forum General Electronics Chat
    Latest: 29th January 2004, 10:11 PM
Tags for this Thread
