+ Reply to Thread
Results 1 to 5 of 5
Thread: Switching problem
  1. #1
    jjj
    jjj is offline
    jjj Newbie
    Join Date
    Oct 2004
    Posts
    11
    Default Switching problem
    I'm having yet another switching problem:
    I want to make footswitch, which turns on an effect. The problem is that, when the effect is switched on, it requires to activate the switch another time to turn the effect off.
    I want to eliminate the latter. That means, I want to press the pedal only for as long as the effect is needed and when I let the pedal go, the effect should turn off.
    That also means that the switching circuit needs to automatically activate the switch another time to turn the effect off.
    How can that be done?
    Click Image to Enlarge Image Hosting
  2. #2
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,422
    If it is a pushbutton typ switch you might modify it to work as a momentary switch.
    Pushbutton type switches are latched a similar way as ball point pens are.
    Removing the small metal bar latching the switch will convert it to a momentary switch.
    This is done within a split of a second.
    Boncuk
  3. #3
    jjj
    jjj is offline
    jjj Newbie
    Join Date
    Oct 2004
    Posts
    11
    Thx Boncuk,
    As it turned out... solving this switching problem mechanically proved to be fairly easy, but only now, I'm thinking a step further: how about implementing this switch into my 120-button accordion bass?
    That would allow me to press any bass & minor/7th button to control the Live-Styler.de (YamahaStyles) accompaniment; surely better than having to knee a lever!
    For that I would need electronic switching. Of course I could do it electro-mechanically, but that would require more power and would be noisier.
    So, my question now is: How to render this mechanical switch (below) electronic?
    (I'm not sure if the PC-Kbd switches respond to fast pulses?)
  4. #4
    shokjok Newbie
    Join Date
    May 2008
    Location
    Alberta, Canada
    Posts
    255
    Have you considered using a mercury tilt switch? It activates the effect when you aim your hand or foot at a specific spot. Another option is a reed switch, activated by a magnet on your instrument or in your footwear, leaving you to activate the effect only in one place.
    If you are motionless when playing the instrument, these ideas could work.
  5. #5
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,422
    If the Yahama life styler is connected directly to the power amplifier you might use a relay activated by the 'now' pushbutton.
    Otherwise the power it has to switch is very low and you might connect it directly.
    Boncuk
+ Reply to Thread
  1. Problem with Remote Switching
    By MegaLord2 in forum General Electronics Chat
    Latest: 24th October 2008, 05:11 PM
  2. Switching problem with 4066
    By jjjjjj in forum Electronic Projects Design/Ideas/Reviews
    Latest: 10th March 2007, 02:35 PM
  3. Help required with switching problem!
    By eimaj12000 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 22nd November 2006, 05:31 PM
  4. Simple PNP switching problem
    By DirtyLude in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th October 2006, 03:20 PM
  5. switching problem??
    By cool in forum General Electronics Chat
    Latest: 11th March 2004, 08:21 PM
Tags for this Thread
