Old 9th January 2009, 08:56 AM   #1
Default How to correct read Relay Datasheet (max voltage load)
Hello
i got a relay RY5W-K i wand to drive small currents at high voltage
(small lamps 5-10 Watt at 230Volts AC from wall plug)
their datasheet - > http://www.fcai.fujitsu.com/pdf/ry.pdf
from the store they told me that i can connect 230Volts AC
but in datasheets sayng max voltage 0.5amp @ 120Vac
they inform me wrong or read datasheet wrong ?
plouf is offline
Old 9th January 2009, 09:03 AM   #2
Originally Posted by plouf View Post
Hello
but in datasheets sayng max voltage 0.5amp @ 220Vac
I read the data sheet as 120Vac.?
Where do you read 220Vac.?
ericgibbs is offline
Old 9th January 2009, 09:04 AM   #3
means 120 corrected
plouf is offline
Old 9th January 2009, 09:07 AM   #4
means 120 corrected
In that case its not suitable for 220Vac.
BTW: has the Greek mains supply voltage been harmonised with the rest of Europe to 230Vac.??
Old 9th January 2009, 09:21 AM   #5
thanx
yes i can read 230vac from voltmeter for many years now.
dunno how many many years exectly but for the last about 8 years i work with electronics yes
plouf is offline
Old 9th January 2009, 09:25 AM   #6
thanx
What exactly are you going to control with the relay contacts.?
Old 9th January 2009, 09:38 AM   #7
not somethink specific
small lamps , or small home appliances
but directly from wall plug
plouf is offline
Old 9th January 2009, 09:41 AM   #8
Relays like this would be suitable.
correct, datasheet, load, max, read, relay, voltage
What is the correct way to drive a 10 amp load from a pic? weegee General Electronics Chat 8 31st July 2008 01:46 AM
Trouble locating the correct relay merleyo Micro Controllers 6 6th April 2008 08:41 PM
How to read a datasheet (74LS04) mdfrahim1 General Electronics Chat 36 20th December 2007 02:18 AM
Is the load impedance provided in the solution CORRECT? powersys General Electronics Chat 2 11th January 2006 03:04 AM
How to know operating voltage for load? rubberlele Electronic Projects Design/Ideas/Reviews 18 5th December 2005 12:50 PM
