Old 8th January 2009, 07:55 AM   #1
Question LM555 output frequency drops when supply voltage from the regulator
I'm using a LM555 timer to produce a frequency of 240KHZ & 50% duty cycle.
The circuit i'm using is Astable. (See Circuit)
RA is 82ohm
RB is 200ohm
C is 0.01uF
RLs nothing
I built up this circuit and got nearly 240K frequency and 44% duty cycle
But when use a normal LM340T5 to produce a 5V to the LM555 timer...
The frequency immediately drop to 190KHZ
This cause my 3rd IC almost burn T^T
anyone can guide me to the solution?
Best Regards
Wan Xi
P/S: Regulator Circuit See HERE
Wan Xi is offline
Old 8th January 2009, 08:16 AM   #2
Do you have a bypass cap on input and output of your regulator?
When you got what you wanted, was your supply voltage from a PS @5v
Pay it forward.
Mikebits is offline
Old 8th January 2009, 09:18 AM   #3
Yes! I did put capacitors. (See Picture)
I tested them seperately. Both are ok.
But when i connect Regulator output to LM555 input..
The frequency just dropped to 190KHZ.
Wan Xi is offline
Old 8th January 2009, 10:20 AM   #4
Sounds like your regulator is not regulating. What is input voltage source? Have you measured the 5 volts on the regulator output?
Pay it forward.
Mikebits is offline
Old 8th January 2009, 10:23 AM   #5
Your output cap for the regulator (or more specifically, the decoupling cap for the 555 timer) is much too small. For TTL 555 timers, you need a HUGE decoupling capacitor (like 10uF) because they actually produce a ~150mA short-circuit due to shoot-through in the internal totem pole output transistors whenever they switch (or so I am told). CMOS versions don't have this problem but have lower drive current.
dknguyen is offline
Old 8th January 2009, 10:26 AM   #6
Originally Posted by dknguyen View Post
For TTL 555 timers, you need a HUGE decoupling capacitor (like 10uF).
Good idea, I always just put a 10uf cap + a .1uf on the reg output as a default.
Pay it forward.
Mikebits is offline
Old 8th January 2009, 11:33 AM   #7
I tried to change both regulator's capacitors to 10uF
But there is no changes. It is still the same waveform.
Below is the image.
Channel 1 is the Regulator Output: 5V, where my input is 6.8V
Channel 2 is the LM555 Output: Freq-194.9KHZ, Duty Cycle-50.1%
Wan Xi is offline
Old 8th January 2009, 11:41 AM   #8
Your input source to the regulator does not have enough current I think. That is why you see big spikes on your 5v. 2v spikes on Vcc are not good. I think you need a stronger supply before your regulator. Like I asked before, what is your input voltage source, and give specs.
Can you power your circuit, including regulator from your bench power supply?
Nice scope by the way
Pay it forward.
Mikebits is offline
Old 8th January 2009, 12:40 PM   #9
RA is 82ohm
RB is 200ohm
C is 0.01uF
RLs nothing
Try to use bigger resistors and a smaller capacitor - The current in the RC timing branch is too high for the power supply and for the 555's discharge transistor at pin 7.
Eg: with 820Ω, 2kΩ, and .001µF (= 1nF) you have the same frecuency with one tenth of the current.
E Cerfoglio
Buenos Aires
Argentina
ecerfoglio is offline
Old 8th January 2009, 05:17 PM   #10
Intersil makes a Cmos ICL7555. In its datasheet they say that the shoot-through current when an ordinary 555 switches is 400mA.
Two supply bypass capacitors should be used. One is a 0.1uF ceramic type to stop the very narrow high frequency spike that the 10uF electrolytic type cannot filter.
audioguru is online now
Old 8th January 2009, 09:35 PM   #11
The datasheet specs a Vinmin of 7.5V. Your 6.8V may not be sufficient to allow your part to regulate properly...
Go Trojans!
saturn1bguy is offline
Old 8th January 2009, 09:46 PM   #12
1) I built up this circuit and got nearly 240K frequency and 44% duty cycle.
2) But when use a normal LM340T5 to produce a 5V to the LM555 timer the frequency immediately drop to 190KHZ.
What are you powering your circuit with when it works properly, i.e. number 1 above?
Go Trojans!
Old 8th January 2009, 09:51 PM   #13
If you need accuracy why are you using a 555 instead of a crystal oscillator?
Bill
Smart Kits build Smart People
Old 9th January 2009, 01:57 AM   #14
I agree that the capacitors are too small but I would go with a 250 uf on the input of the reg and a 1000 uf on the output. That should smooth things out
Mike2545 is offline
Old 9th January 2009, 02:11 AM   #15
Bingo!.............
I've never advocated drugs, alcohol, violence or insanity, but they have worked well for me!.......Hunter S. Thompson
GonzoEngineer is offline
drops, frequency, lm555, output, regulator, supply, voltage
Output from voltage comparator drops to 0.6 V when connected to micro controller? Drohm Electronic Projects Design/Ideas/Reviews 7 4th May 2008 06:41 PM
2.5v Voltage Regulator. Output is only 1v???? Almazick Electronic Projects Design/Ideas/Reviews 14 18th February 2007 02:49 PM
Diode voltage drops brodin General Electronics Chat 10 1st April 2005 01:21 PM
Why use 2 capacitor at output of voltage regulator? StupidDum General Electronics Chat 4 27th October 2004 04:11 AM
Hi Voltage Power supply regulator badflyer Electronic Projects Design/Ideas/Reviews 2 14th October 2003 11:48 AM
