Old 5th January 2009, 02:30 AM   #1
Default Temperamental crystal circuit
Hi all,
No doubt some of you will have been following the saga of my PIC-driven clock project. Today it has taken a weird turn as the crystal circuitry has started to misbehave.
The schematic:
  |-<32768>-----|
  --[10M]-[220k]--> out     Legend: <32768> = crystal, [ ] = resistor, ( ) = capacitor
  |      |      |                All junctions are connections
  --|>o--|      |
 (33)          (33)
  0V            0V
(|>o = NOT gate = 1/6 of a 4069)
Here's the puzzle. My circuit is powered by a 4.5V battery supply which is enough to power the PIC/display but doesn't seem to get the crystal ticking. I previously powered the 4069 with 9V, so I tried that and it works. It also continues to work if, after starting off at 9V you take the wire out and connect it to the 4.5V supply.
If you reverse that (start with the 4.5V batteries then connect it to the 9V supply) the crystal does NOT work. So,
1) Why this weird one-way phenomenon? I checked after disconnecting the 4.5V supply and the voltage was at zero everywhere, so I don't think there was any charge left in the capacitors or anything (they're tiny anyway).
2) Is there some simple fix e.g. reducing the values on the resistors so that it works at 4.5V?
3) I also have a 2MHz crystal - do I need to make any changes to the above circuit to get this working. (not so urgent)
Thanks,
ahydra
ahydra is offline
Old 5th January 2009, 02:53 AM   #2
I don't know if this will make any difference, but you should be taking your output from the 4069 output.
Ron
Roff is online now
Old 5th January 2009, 08:42 AM   #3
As per Roff's suggestion but I would go a step further by adding another 4069 to buffer the oscillator output and then use it, provided that there are "free" 4069 sitting there.
L.Chung
eblc1388 is offline
Old 8th January 2009, 02:33 AM   #4
Neither idea worked unfortunately. I think the problem was either I had the circuit set up wrong or simply FM (F***ing Magic - i.e. it just randomly disappeared), as today I rebuilt it and it works, even using the same set of batteries as before.
Do either of you/does anyone else know what component values I should use for a 2MHz crystal instead of the 32768Hz? The load capacitance is 32pf, and from websites I have found the capacitors should therefore be about 54pf (I'm getting some 56pf's). But nobody seems to want to tell me the ideal values of the resistors.
ahydra
ahydra is offline
circuit, crystal, temperamental
Trimmable Crystal oscillator circuit Boncuk Datasheet/Parts Requests 10 6th May 2008 10:11 AM
Crystal or Crystal Oscillator? eblc1388 General Electronics Chat 4 21st August 2005 05:43 PM
27mhz crystal oscillator circuit Spectacular Butter General Electronics Chat 15 3rd December 2004 04:17 PM
Testing a crystal oscillator in circuit McGuinn Micro Controllers 6 30th July 2004 02:56 PM
Simple crystal oscillator circuit canadianpoet2012 General Electronics Chat 10 1st July 2004 04:37 AM
