Old 23rd March 2009, 07:25 PM   #16
Originally Posted by MrAl View Post
If i followed your notes then perhaps you can use a time period
solution that is known to work with all time but cant be employed
for all time because it isnt appropriate for some time periods.
That is, take (for example) two 10k resistors and use them as
pull downs, but dont connect them directly to ground but instead
to the collector of an NPN transistor (emitter to ground). When the
transistor is on, the gates are pulled down close to ground, and when
the transistor is off, only the collector leakage current flows.
The only task left then is to figure out a way to generate a timing
pulse to the base of the NPN. Perhaps with charging cap (+Vcc to
base plus series resistor) so that at the instant of turn on all the
gates get pulled down, but that only lasts until the cap charges.
Ditto with a MOSFET for the controlling device instead of NPN.
The MOSFET would even be faster, and gate timing could be
made such that the pull down circuit pulls down faster than any
gate can turn on.
Another approach might be to use a dedicated uC pin, delaying its
effect with a capacitor so that it has to hover at some stable
logic level in order to charge the cap, and charging the cap
turns off the pull downs with appropriate transistor circuit.
hi MrAI,
i am new to electro-tech..
could you explain how to use a MOSFET in the pull-down circuitry which stays open after power up and connects the pull-down resistor to ground when the gate driver is powered down.
could you tell how to generate the time pulse that you were talking about?
patwardg is offline
gate, mos, pulldown, resistor, safety
Pull up resistor Help! stolzie Micro Controllers 7 23rd August 2006 11:04 PM
Pull up resistor substitution ? Screech General Electronics Chat 6 30th July 2005 01:53 AM
Pull Down resistor selection ? 2camjohn General Electronics Chat 3 3rd January 2005 07:00 PM
Bus pull up resistor value Dialtone General Electronics Chat 1 27th December 2003 09:00 PM
CMOS pull up/down resistor bogdanfirst General Electronics Chat 2 12th August 2003 06:10 PM
