Hello, I'd like to know if it's possible to wire around 6 or more SPDT functions to one switch? Do those exist? I'm wiring modifications and different resistor values inside an amplifier. And I'd like to switch back to all the stock values with the flick of a switch, and so I need an SPDT function switch that can do around 6 functions at once. For switching back and forth from stock to a modified circuit. Thanks | |
| | #2 | |
Are you looking for a 6PDT switch ? You could use a SPST and have it power the coil on a relay or relays with enough contacts. Maybe use 2 3PDT relays. It might be cheaper then a single 6PDT. Quote:
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | ||
Yeah something that works like a 6PDT switch. A relay with a SPST switch sounds about right. What would I need? | |
| That depends on what you are switching. Current and voltage. The relay contacts need to be able to handle whatever it is.
Generally speaking, when you start using a massive switch to do all that you want to do, you end up with a lot of problems with feedback, crosstalk and ground loops. What you want to do may be theoretically possible, but not the least bit practical. But try it anyway, but be prepared for some surprises! Dean
| | #6 |
At my work we had a box that we called a T-bar switch. It was used to switch the input/output digital interface for our plant control system to two different general purpose computers. It was part of a fail-safe back up method designed in the late 70s. Anyway inside were four 24vdc 48PDT relays with all four coils wired in parallel. I guess during testing and commissioning (before I worked there) they found that the two general purpose computers didn't like having their signal grounds wired together so they needed enough contacts to switch both signal and ground for all the signals. What a monster and because of the low current signals being switched it seemed the contacts would get a little flaky every few years and we would have to replace relays to prevent intermittent errors. What a mess to work with. They should have used a custom made optical isolator array but I heard that the ground compatibility problem showed up only late in the project so the relays were the quickest thing they could come up with that worked. Of course those engineers left with project completion and we were left supporting the kludge until the control system was upgraded in 2002. Lefty
__________________ Measurement changes behavior Last edited by Leftyretro; 30th December 2008 at 04:29 AM. | |
| functions, spdt, switch |
| How do I test an SPDT relay? | mrlooneytoon | Electronic Projects Design/Ideas/Reviews | 10 | 28th October 2008 02:31 PM |
| spdt relay usage???? | dark scorpion | General Electronics Chat | 2 | 17th May 2008 05:34 AM |
| MAX4564 (SPDT analogue switch) | TronicBrain | Datasheet/Parts Requests | 6 | 8th February 2007 12:33 PM |
| low noise, real analog SPDT switch.. | cjoseph2 | Electronic Projects Design/Ideas/Reviews | 9 | 22nd August 2005 12:14 AM |
| 500K Or About Pot With A Rotary SPDT Switch? | sjaguar13 | General Electronics Chat | 3 | 1st July 2003 06:07 AM |
