Hi Abbas,
thanks for the flowers.
I'm just a perfectionist, nothing more but also nothing less. If I get a package "served" I normally check the truth before using it for a design.
(absolutely no drive to mess around with false dimensions of any part.)
If you want to use that library, containing nothing but a package I recommend to put it in your '.lbr' directory.
To create a device you must make a symbol first. Save the symbol with the pad numbers (I prefer pads instead of pin names and name the pins within the symbol for easier tracking in the PCB layout, which is also very useful when debugging a circuit.)
Use the symbol to create the device and assign the package (SOT23-6). Assign the pin numbers and you're done after saving the device.
BTW, there are some key dimensions in any component to be used:
The body size is of minor importance and can be negligated in most cases. It will result automatically using the correct pin spacing horizontally and vertically. Most important is the factory given soldering foot print which must be true for any deviation of outer dimensions of the part.
Draw the footprint first and add the outline of the package when finished. The more accuracy you apply the more likely the part will fit without measuring the dimensions physically. My selfmade minimum requirement is 1/100mm.
Kind regards
Boncuk
P.S. And of course you can make double sided PCBs with the free version, but restricted to a board size of 100X80mm (3.94X3.15inches)
