I want to install CCTV cameras for the purpose of watching livestock in a shed which constructed from corrugated galvanised mild steel. The distsnce between camera and monitor will be approximately 150/200 metres.
I can buy (1) a wirless system "of the shelf" quite cheaply, but the range is only about 30 metres and I have been advised that the metal walls of the shed will obstruct the signal. Is there a way I can boost the wireless signal.
or (2) a wired system which has a 10 metre signal cable attached and offers an option of 50 metres extension cable. The information on the box advises that the max distance is 50 metres.Is there a method I can use to boost the signal to give a good reception.
I would appreciate advice on the best alternative in this case.
Regards.
J McGivern
