Old 26th December 2008, 04:25 PM   #1
Unhappy Weather Station
hi guys, pls help
Iam trying to design a weather station with the following requirements;
The Data required to be collected are Temperature, Wind Direction, Wind Speed and Atmospheric Pressure. Im not sure wot sensors should be used?. The system should include signal conditioning and amplification that may be needed for each sensor, the maximum input to the A/D converter is to be limited to 5V DC.
any tips and advice would be very much appreciated.
I hope you guys can spare a minute or 2.
Thanx!
jigzpad is offline
Old 26th December 2008, 05:12 PM   #2
Originally Posted by jigzpad View Post
hi guys, pls help
Thanx!
There is much on the web showing various sensors and methods and it can vary from pretty simple and basic to quite involved and expensive. First you have to define if you wish for wireless or can run signal and power wires between your outside instrumentation and your A/D and readout device.
The only thing I will pass on here is about the pressure sensor for reading barometric pressure changes as many people select and purchase the wrong kind of pressure sensor. You will need to make sure your pressure sensor is of the absolute pressure type rather the the gauge (of differential pressure) type. The data sheets for pressure sensors are not always crystal clear on what type they are and the proper one will state absolute pressure somewhere in the data sheet. Only the former type has a vacuum reference pressure built into it so as to be able to track atmospheric pressure changes.
Lefty
Measurement changes behavior
Leftyretro is offline
Old 26th December 2008, 07:26 PM   #3
Temp: LM35
Press: Honeywell SDX series
More ? Google!
Cheers,
Hannes.
captainhannes is offline
Old 26th December 2008, 08:08 PM   #4
One can not talk about weather stations without mentioning Dallas 1 wire networks.
3v0
BCHS/3v0's Tutorials
3v0 is online now
Old 26th December 2008, 09:40 PM   #5
Smile
3v0,
absolutely, Dallas/Maxim also makes cool stuff:
Sensors (Including IEEE-P1451.4 Plug-and-Play Sensors) - Parts List
Cheers,
Hannes
Old 26th December 2008, 10:10 PM   #6
Since everything is going to a ADC, you're going to want to keep everything analog obviously. For a temp sensor, look at the AD590. Windspeed will have something mechanical involved but could end up as a frequency to voltage converter. Wind direction, again something mechanical. Do they want you design the mechanical parts, or are they already known..
colin mac is offline
Old 27th December 2008, 08:53 AM   #7
hi guys, pls help
Thanx!
Look at Oliver's setup, most excellent.!
Weather Display Live Kenley
ericgibbs is offline
Old 27th December 2008, 08:58 AM   #8
Purchasing a cheapy weatherstation desk top toy and tapping the sensor outputs into a PIC might be the go.
bassnut is offline
Old 27th December 2008, 09:54 AM   #9
If you want a weather station including the observation, collection and evaluation of weather data and phenomena for a local weather forecast you should risk a look into ELV - Das Elektronik-Versandhaus | ELV Elektronik.
They have a wireless weather station and offer lots of sensors with it, e.g. amount of precipitation, relative and absolute humidity, dew point calculation etc.
Check for "Funkwetterstation".
Caution: The weather station works only with the custom developed chip by ELV.
Boncuk
Boncuk is online now
station, weather
Let Us Work Together For a Weather Station theo92 Micro Controllers 7 25th November 2008 02:24 AM
Weather station sensors? HarveyH42 Electronic Projects Design/Ideas/Reviews 32 13th May 2008 05:53 PM
Weather station controller? wellu_ Micro Controllers 5 12th October 2007 09:03 PM
Electronic Weather Station Project Kevin Gallagher Electronic Projects Design/Ideas/Reviews 2 29th April 2004 12:01 AM
Weather station ala199 Electronic Projects Design/Ideas/Reviews 7 17th March 2004 02:46 AM
