+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 19 of 19
Thread: long range sensing
  1. #16
    ahmedragia21 Bad
    Join Date
    Apr 2006
    Location
    Egypt,Cairo
    Posts
    412
    Unfortuantely , the kit you showed me later , is only 0.2 m ...
    so its not really possible to do this thing ? im really wondering
  2. #17
    ahmedragia21 Bad
    Join Date
    Apr 2006
    Location
    Egypt,Cairo
    Posts
    412
    The problem with the laser idea , is it can be seen by the thief , so its not really a good idea ...
    Would you explain it more ?
  3. #18
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,796
    Blog Entries
    13
    Quote Originally Posted by ahmedragia21 View Post
    just like that O -------------------X <-- object
    i really wanna do it to detect a human passing near that sensor then do an alarm
    You could try a laser pointer with a remote 2.5cm prism, detect loss of return beam.
    That is an interrupted laser pointer beam.
  4. #19
    user_88 Newbie
    Join Date
    Nov 2008
    Location
    Texas
    Posts
    415
    Hi, Im trying to sense if there is an object at 100m ? can infrared do it or ultrasound ??
    Consider this:
    You have two telescopes of some sort ... maybe spotting scopes .... probably whatever you can afford. Each scope is placed on a line several meters apart, and sighted in on the target .... 100 meters away. When you have sighted and focused each scope on the target, you remove, affix, ... or somehow place ... a phototransistor or some other optically sensitive IC at the focus point of each telescope. .... You might describe this as a 'parallax' method. The final step would be to enable an AND logic gate to alert you when both scopes had sensed the same target at the same time.
    The success of this method would depend on whether you could get the target object to create enough of a contrast signal in the phototransistors to switch logic states.....
    Some additional improvisation and testing might be necessary... not certain how far apart the two scopes would have to be separated.
    You wouldn't want to have a false positive .... if an object nearer than the target was lengthy enough to trigger the alarm.
    A Charge Coupled Device type of sensor, as used in cameras or astronomy, might have a better chance of providing a signal indicating that the target is
    present. However, a CCD would require a more complicated interface circuit.
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Long range FM transmitter
    By sudhan shrestha in forum General Electronics Chat
    Latest: 9th February 2010, 12:32 PM
  2. long range fm transmitter
    By dasappettan in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th December 2009, 01:05 PM
  3. need of long range IR transmiter
    By compass1982 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th February 2009, 11:19 AM
  4. Long range forecast
    By RobertRoss in forum General Electronics Chat
    Latest: 4th September 2008, 02:58 AM
  5. long range IR remote
    By Flyingmunkie in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st December 2006, 12:05 PM
Tags for this Thread
