| | #46 |
I wonder what was not right about the way I did it.
| | #47 |
| Hi there, I like the way you approached this problem in looking at the areas. I think however that you just need to modify that technique a little, where instead of looking at the area under f(x) you need to look at the area under (f(x))^2. In other words, instead of finding the area of those little triangles shown in the pic of the wave (which have three straight line sides) you would need to first square them for all time and this would yield little triangles with one curved side and two straight sides. I'd like to see you do this again making that one little modification and am betting your idea will work after that and you'll get the very same answer. I really do hope you try this again i'd like to see the result too. | |
| | #48 | |
I did do that. I squared the Y-axis values (or height) before multiplying them by 1/2*base. I just stopped saying the "square of the function" because I've said it like about 20 times in my previous posts and it got very confusing to follow the post with such a frequent wordy phrase. Quote:
| | #49 |
Hi again, Well, what you have done is made bigger triangles by squaring the height of the triangle alone, when you really have to square the entire triangle over time t. When you use a formula like 0.5*base*height, that means you are sill using a triangle that has three *straight line* sides (ie a normal looking triangle) when the triangles that really represent the area have only two sides that are actually straight and the part of the triangle that is normally slanted (and straight) becomes a curve instead of a straight line. You'll have to figure out some way to calculate the area of that new pseudo triangle (it isnt really a triangle anymore). Here is an illustration showing the difference this really makes: Last edited by MrAl; 10th January 2009 at 12:56 AM. | |
| | #50 |
Ahhh, i see now. A sloped line that is squared...obviously becomes a curve! I see now. It does not scale linearily.
| | #51 |
Hi again, Yes :-) and i posted a pic to illustrate this but i think you replied while i was drawing it. You might still find a way to work with that new type of triangle though. | |
| | #52 |
Hi thank you for the solution, and also for the explanation here: here is another approach of solving this problem. The Delta signal between 0 & T/2 has already the RMS of i /sqrt (3). The constant value between T/2 and T has the RMS of i Both value will be squared, with the time T/2 multiplied, and add The sum must be at the root, therefore the result is: i * sqrt (2/3) thanks again! Last edited by tintincute; 12th January 2009 at 07:49 AM. | |
| determine, rms |
| How to determine between norton and thevenin | Peter_wadley | Math and Physics | 4 | 31st August 2009 10:45 AM |
| How does one determine the capacitance of a coupling cap? | potoole64 | General Electronics Chat | 18 | 23rd September 2008 03:22 PM |
| How to determine polarity of a coil | turbobill | General Electronics Chat | 18 | 3rd May 2007 10:39 PM |
| Can someone help me determine what rectifier to use? | scatterbrain | General Electronics Chat | 8 | 24th October 2006 04:46 AM |
| determine battery level | electricano | General Electronics Chat | 10 | 16th December 2003 05:39 AM |
