+ Reply to Thread
Page 4 of 5
First 1 2 3 4 5 Last
Results 46 to 60 of 61
Thread: Series Regulation
  1. #46
    premkumar9 Good premkumar9 Good
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Quote Originally Posted by kchriste View Post
    Ok, let me explain it to you this way. Let's say you have 12V, a LED string with a Vf of 10V, and a 100Ω resistor in series. This means that there will be 2V across the resistor and 20ma will flow. That will mean there is 40mW wasted in the resistor.
    Now, let's say you have 14V, a LED string with a Vf of 10V, and a 100Ω resistor in series. This means that there will be 4V across the resistor and 40ma will flow. That will mean there is 160mW wasted in the resistor with no PWM. Now if we PWM it at 50% that means that an average of 80mW would be wasted in the resistor and an average of 20ma will flow.
    If you have 14V, a LED string with a Vf of 10V, and a 200Ω resistor in series then there will be 4V across the resistor and 20ma will flow. That will mean there is 80mW wasted in the resistor with no PWM.
    As you can see, there is no power saving using PWM without an inductor.
    I agree with all your explanations. Pls see the following explanation and correct it if you find necessary.
    Take the same example.
    At 12V input with out PWM current taken is 20mA. So power from 12V is 12x0.02 = 240mW.
    At 14V with out PWM power = 14x0.04= 560mW
    With 50% PWM power from 14V = 14x0.04/2 = 280mW only.(extra 40mW in the resistor. But total power has come down drastically)
    Am I Right?
  2. #47
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Quote Originally Posted by audioguru View Post
    Leds are less efficient at high peak currents. They waste the extra power as heat.
    Your current-limiting resistors also waste the extra power as heat.
    A buck regulator stores power, it doesn't waste power.
    Philips Lumileds make buck and boost converters that have the inductor built-in and they are very efficient. They sense and regulate the average current.
    Yes. Here there is an important point. Whether these high brightness LEDs use for traffic lights are suitable for dynamic display. Their light O/P unlike some other type of LEDs may not increase much with increase in current from 20 to 40 mA. Then with this type of regulation, the lights will become dim when input voltage increases since duty cycle is is reduced.
    In that case buck converter alone will be solution.
  3. #48
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    Quote Originally Posted by premkumar9 View Post
    Am I Right?
    Yes, but your LEDs will be 1/2 as bright because the average current is now 20ma with 50% PWM vs 40ma without it.
  4. #49
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    With 12V also the average current was 20mA only. But it was continuous. Here it is 40mA with 50% duty cycle keeping the average as 20mA. So brightness should be same if the light O/P of LED varies proportionately with current (which may not be true in this case as audioguru pointed out).
    Right?
  5. #50
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    Why not build a test circuit? A simple 555 timer and a variable resistor to limit current plus an LED and see how duty affects brightness.
    Bill
    Smart Kits build Smart People
  6. #51
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Quote Originally Posted by blueroomelectronics View Post
    Anyway I will be doing that with the MC and driver. But I put these doubts in the forum to get the opinion of people with practical experience so that I can save time and learn from their experience.
    I had done dynamic display earlier and observed the brightness variation.
  7. #52
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,880
    I use MV8191 red LEDs. The luminous intensity at 40mA is only 1.7 times the amount at 20mA so the brightness is not doubled. Your LEDs might be different.
  8. #53
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    From the data sheet of MV8191, it seems to me that intensity Vs If characteristics is suitable for dynamic display, but light O/p is less for traffic light application.
  9. #54
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,880
    The MV8191 is diffused and has a 45 degrees beam angle. The MV8141 is the same chip but is 40 degrees and is almost twice as bright since its package is clear.
    Its curves show that it does not get very bright with high peak currents.
  10. #55
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,724
    If you still want to use a voltage regulator, why not use a buck-boost switching regulator?
    Ron
  11. #56
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Quote Originally Posted by Roff View Post
    Can you pls suggest any link to learn about the buck-boost regulator you suggested?
  12. #57
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    A very useful reference manual for SMPS.
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  13. #58
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Quote Originally Posted by ericgibbs View Post
    Thank you very much. I just had a glimpse. Seems to be very useful. I will definitely use this as a reference.
    What is this 'buck boost' actually? Is it same as fly back converter where we can have the o/p voltage higher than input voltage?
  14. #59
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    This and other Google links for buck boost converter describe the operation.
    Buck-boost converter - Wikipedia, the free encyclopedia
  15. #60
    Join Date
    Oct 2008
    Location
    India
    Posts
    368
    Thank you very much
+ Reply to Thread
Page 4 of 5
  1. BB Regulation help
    By 3v0 in forum Micro Controllers
    Latest: 18th December 2008, 01:24 AM
  2. 24v - 12v Regulation
    By Pcolaboy in forum General Electronics Chat
    Latest: 8th May 2008, 12:31 AM
  3. Interfacing 4000 series CMOS to 74HC series TTL
    By kd4pbj in forum General Electronics Chat
    Latest: 22nd January 2007, 04:53 PM
  4. Difference between 4000 series and 7400 series?
    By ghall426 in forum General Electronics Chat
    Latest: 1st January 2007, 01:01 AM
  5. psu regulation
    By monkeytree in forum General Electronics Chat
    Latest: 31st January 2006, 12:26 AM
Tags for this Thread
