| Hey folks! I need some advice on troubleshooting a computer power supply. I've read through the previous posts on Computer power supplies. Here is what I have so far: 400Watt ATX type PS. Model LPK2-30 (Datasheet available???) 1. The PS has been used on a continuous basis. (the PS and computer remained on for long periods of time (weeks at a time.). 2. When the power switch is pushed, the computer begins to boot, then suddenly turns off. This leads me to believe that the connection between pins 14 & 15 (PS On, and GND respectively)is possibly being opened, causign the PS to shut off? 3. Planning to short pins 14 & 15, and add a load to the supply (possibly fans or high wattage resistors) in order to measure the supply voltages. 4. Inspected the internal PCB for evidence of overheating / shorting. No signs are evident. 5. Inspected internal fuse, Good to go. Does anyone have any other ideas for troubleshooting this issue? | |
or try putting the PS in someone elses computer and trying it then (it could be a motherboard issue) I know this isn't in the spirit of this site, but you can get a standard 2-fan 400W PSU for about £10. To be honest, its probably not worth messing around with it, except for the purpose of educating yourself. My advice: buy a new one (to put in your computer), see if you can get the old one to work, then use it or its components in your next major project. - Do you really want a 'repaired' power supply in your computer? (you may have missed something, and this something could ruin you motherboard or worse) Hope this is some help :? Tim. | ||
| You have a good point. Why try to fix the PS, and potentially create more problems, when the PS are pretty cheap anyhow. I suppose I'll keep this unit around to mess around with, and purchase a new PS. Thank you for your time! | |
Check for dry solders.... Getting hot may cause them to lose contact... | ||
| Hello, After the initial bootstrap, a disk start command is sent, may be something out of order in the HD that takes too much current and the overcurrent sensor is tripped. May be. Regards | |
