I dont have much knowledge about electronic devices but I am working on a project. I have a bluetooth module which needs an supply voltage of 3.3 V and the minimum of 150mA supply current. I have bought a voltage regulator that has a maximum output of 800 mA and output voltage of 3.3V so that it converts the 5 V ouput from the pic board to 3.3V to drive the bluetooth module. My question is how would i reduce the 800mA to 150 mA as it would damage the module if more current passes through it. | |
You don't, it will only take the current it needs - the capacity of the supply makes no difference (as long as it's big enough).
| That concern about current seems to be a common misconception about voltage regulated power supplies. A voltage regulator supply regulates the voltage, not the current. The current rating is just the maximum current it can safely deliver to a load, not the amount of current it delivers all the time (that would make it a current regulator, not a voltage regulator). As Nigel stated, if you apply the correct voltage to the module, then it will draw just the current it needs.
__________________ Carl Curmudgeon Elektroniker | |
There are some sensible concerns over current rating:
#1 can be solved by adding a voltage regulator and #2 by adding a fuse or PTC resistor. A classic example of: #1 is using an oversized wall plug and #2 is using a car battery to power a small radio.
thanks pple!.. Appreciate the help.. | |
| regulation, voltage |
| Help with Voltage Regulation | Pete Olsen | General Electronics Chat | 4 | 9th December 2008 01:10 PM |
| Voltage regulation | Joe McGivern | General Electronics Chat | 8 | 11th June 2008 09:46 PM |
| Voltage Regulation | Carnivore | General Electronics Chat | 6 | 15th January 2007 01:45 PM |
| Regulation to same voltage | grrr_arrghh | General Electronics Chat | 8 | 11th July 2004 05:55 PM |
| voltage regulation for fan | kvos | Electronic Projects Design/Ideas/Reviews | 3 | 13th March 2003 05:42 AM |
