Old 8th December 2008, 07:25 PM   #1
Default Help with Voltage Regulation
I know how to regulate 5 and 12 volt circuits, but how would I regulate 7.8 vdc supplied by a 12 vdc source?
Pete Olsen is offline
Old 8th December 2008, 07:38 PM   #2
Take a look at the LM317. It's probably the most common solution. However, you didn't mention the current requirements of your application.
eng1 is offline
Old 8th December 2008, 09:15 PM   #3
Use an LM7808 which gives 8V and is close enough to 7.8V for it to work.
if I know the answer.
Hero999 is offline
Old 9th December 2008, 02:39 AM   #4
Default 7808 Regulator
That sounds like a good start, thanks.
Also the current load is 1.7 amps.
Old 9th December 2008, 01:10 PM   #5
That's above the current rating of the regulator which is 1A.
You can build a current booster (see datasheet) or use a higher rated regulator.
What's the minimum load current?
If the current isn't expected to drop below 700mA another trick is to connect a power resistor across the regulator.
For example the voltage difference between the input and output is 4V so connecting a 4R resistor from the input to output will allow 1A around the regulator (which will only need to pass 700mA) and will work fine providing the current used by your device is >1A As soon as the current drops below 1A then the output voltage will rise which could destroy the appliance being powered.
Hero999 is offline
regulation, voltage
Voltage regulation Joe McGivern General Electronics Chat 8 11th June 2008 09:46 PM
Voltage regulation lor_kev Electronic Projects Design/Ideas/Reviews 9 16th April 2008 04:26 PM
Voltage Regulation Carnivore General Electronics Chat 6 15th January 2007 01:45 PM
Regulation to same voltage grrr_arrghh General Electronics Chat 8 11th July 2004 05:55 PM
voltage regulation for fan kvos Electronic Projects Design/Ideas/Reviews 3 13th March 2003 05:42 AM
