| i have read in books that in a transistor the voltage between two terminals control the current through the third terminal. like in a common emitter (or common source) amplifier the voltage between base and emitter (voltage between gate and source for the case of FET) controls the amount of current in the collector (or drain) terminal. this explains how transfer of resistance occurs in a transistor and why the device is named so. some people dont like to explain "transistor action" like this. the transistor can also be thought of a current controlled device. in that case the current in the base controls the current in the collector. now for my question. in a common collector configuration what is the situation. the voltage between which two terminals is controlling a current through the third terminal. please explain. thanx in advance | |
| In a bipolar transistor, the current from base to emitter creates a current from collector to emitter that is Beta times the base current. The emitter current is Ib*(Beta+1) and the collector current is Ib*Beta.
my question was something else. | ||
| | (permalink) | ||
The voltage between base and emitter is pretty well constant, it's not voltage controlled - thinking of it as so will prevent you understanding how circuits work. All three transistor configurations basically work in the same way, base current being amplified by the transistors gain to give the collector current, with the emitter current being the sum of both. If you're talking FET's, they are voltage controlled, but bipolar transistors are current controlled. | |||
| One way of looking at a common collector (emitter follower) circuit is as a negative feedback circuit. The control voltage is not applied between two terminals of the transistor, but between the base and another node in the circuit (usually defined as ground). The emitter voltage will follow the base voltage with just enough offset (diode drop) to satisfy the condition Ib=Ic / beta. | |
| | (permalink) | ||
the way u r looking into a transistor has a flaw. when u think of a transistor as a current controlled device u apply the equation Ic = BETA * Ib whereas everyone knows that BETA changes alot so we dont use the transistor in this way. one way to get rid of this is by including the emitter feedback resistor. in that case Ic is not equal to BETA * Ib. and when u think of Ib the controlling factor there is also a need for it to be zero. because if Ib is zero Ic=Ie and thats what we want. so how can Ib be the controlling factor when we dont need it to be there in the first place. now all that i have said is no BULLSHIT. if u have the book Microelectronic Circuits u can see this explanation. and that book is the most used book by engineers all over the world i have said that the current controlled behaviour is somewhat ok. if u want to visualize it that way its alright. | |||
Voltage control of collector current is highly useful in logarithmic converters and in current mirrors. It is useful to think of common emitter amplifiers (especially digital switches) as current controlled. Voltage and current are interrelated by the diode equation (Google search). | ||
| ok so this is how the story goes in a common emitter configuration without the emitter feedback resistor the following equations apply Ib = (Vbb - Vbe) / Rb where Vbe is 0.7 for silicon now Ic is BETA times Ib and Vce = Vcc - Ic*Rc now if u calculate the q-point using these equations it will be highly unstable because of the unstable value of BETA. it changes with temperature. now if u add an emitter feedback resistor the operating point can be calculated without the BETA. so this operating point is independent of BETA and it will be stable to the changes of BETA due to changes in temperature. The following equations apply. Ve = Vbb - Vbe Ic = Ie = Ve / Re Vc = Vcc - Ic * Rc and Vce = Vc - Ve as u can see from the above equations there is no Ib or BETA involved. so when we need stability we dont see the transistor amplifying an input current. when u use the configuration without the emitter feedback resistor u can say that the transistor is a current controlled device and Ib is the control current. but with that we also need Ib to be zero so that Ic=Ie. so how can a thing be a controlling factor when there is no need for it. now in the configuration with the feedback resistor Ib isnt involved in the calculation of the Q-point. with this we acheive stability. so by the exclusion of Ib we made a good amplifier. now do u think Ib is worthy to be called a controlling factor? its actually the voltage that controls the current and i already told u people that this isnt my own thoughts. my question was something different which nobody has been able to answer PLZ READ MY QUESTION FIRST why is it that whenever i post a question in this forum nobody seems to give me the answer. | |
A transistor is still current controlled, the current gain is what makes it work. Adding a resistor in the emitter may gave an illusion that the base voltage is controlling it, but it's still just the base current. The reason for this illusion is that as the base current increases the collector and emitter currents increase as well. As there is a resistor in the emitter the voltage on the emitter will increase, reducing the base current, giving negative feedback. In your formulas you ignored the most important part - Ie is not equal to Ic, Ie = Ic + Ib. As I also mentioned previously, all three transistor configurations work the same - it's only the input and output which are different. To recap: Bipolar transistors require base current, they are current driven. FET's don't require gate current, they are voltage driven. Valves don't require grid current, they are voltage driven as well. Try putting a microammeter in the base lead of a transistor, you can measure the current it's driven by!. Do the same for an FET and a valve, no current is displayed. | ||
| | (permalink) | |||
i know that there is some base current in every BJT circuit. but that doesnt mean that it is controlling the output. that is one of the major drawbacks of BJTs that it draws base current. plz do have a look at the article i know most of u think that BJTs are current controlled devices (even my electronics teacher teaches us that). All over the world people consider the transistor as a current controlled device. and i dont have any problem with it the problem is that the current controlled model has a flaw and it doesnt apply everytime. plz read the article and my recent posts and then think about it. dont try to shove this current controlling stuff down my throat. it is convention to think of the BJT as a current controlled device because it is easy to explain but that doesnt mean it is true[/quote] | ||||
| | (permalink) | |||||
But just because you ignore them doesn't mean they aren't there, nor that they are what is making it work. If you are using the transistor anywhere near it's limits you need to take them both into account. Quote:
He seems mainly to "play with words", talking about "current doesn't flow", but charge does. In my opinion (and experience) there are two schools of thought - both basically the same. The older one, conventional current, flows from positive to negative - the more modern one, electron flow, is the actual flow of electrons (from negative to positive). It makes no real difference which you use, and you should be able to simply interchange between them without a second thought. Quote:
| | (permalink) | ||||
I read your orginal post and the article you've posted about how to visualize transistor action. I've seen this article a few times in various forms before. I think it arguably(sp?) does provide an alternative explanation if that is what you are looking for. But please do not lose sight of a simple fact. The "conventional" explanation of how a transistor works has been in successful use for many many years. And if one has a model (mathematical or otherwise) that works, its ok to use provided it explains the phenomenon via the scientific method. If someone believes the conventional explaination is full of errors (like the article mentions), I'd like someone to point them out specifically (which, the article did not do) so we can look at it. Truth is, the explanation of transistor action has been thought about and analyzed for much much longer than we've been around (well, maybe except for RON H :wink: ) so we've gotta stake some faith in that. | |||||
| thanx Optikon. u know why i like to view the transistor as a voltage controlled current source is that i have seen this explanation in the best books around e.g Microelectronic Circuits by Smith/Sedra and Electronic devices and circuits by Theodore F Bogart and i do say that visualizing the transistor as a current controlled current source is a good thing. but my question was something else. i wasnt asking that is the transistor a current controlled device or a voltage controlled device. my question was Quote:
| 8) In the bipolar transistor the base-emitter voltage control the collector current, the base current not have any controll over collector current, the base current is parasitic and in an ideal case must be zero. The belive that the bipolar transistor is a current controlled device is incorrect, but seem to be very popular between peoples on this forum, for that some explanations about internal transistor working must be maked. The transistor have 2 junctions: emitter junction(between B-E) and collector junction(between C-B). In normal operation the collector junction is reverse polarised and emitter junction is direct polarised. For case of NPN transistor, the emitter junction will inject electrons from emitter N region into base region, and gaps from base region into emitter, but because the emitter is very heavy dopped and base is light dopped the electrons injection is more more higher than the gaps injection. This injection is controlled by voltage over the emitter junction like every PN junction. When the electrons from emitter go into base region they will be into region rich in gaps and have tendency to recombine with this gaps, but because the base is very tick this recombination is very low and allmost all electrons arrive to collector junction border. At this border they are accelerated by reverse voltage of junction to go into collector region where form the collector current. The same reverse voltage will bloc the gaps from base and electrons from collector to cross the junction, so if is no electrons injection from emitter region through base then is no current through transistor. This is the simple explain on how transistors really work. Now you can view that the B-E voltage controll the electrons injection and controll the collector current. The base current is give by gaps injected from base to emitter and from electrons that have recombined into base, so the beta factor is higher if emitter region is more higher doppen relative to base dopped, and if base region is more tick than before. The base current appear from unwanted fenomens and is a secondary effect of main one, it have no effect over collector current controll. But because the transistor need to be feeded with a current into base for compensate the base charge that flow from base into emitter, only APPARENTLY the base current controll the collector current. I hope I'm clear enough in my explanations. | |
