hi there everyone, im new to this forum and i need your help please. im fitting an aftermarket tacho to a yamaha R1 motorcycle. the tacho that im fitting needs to be triggered by a 12 volt square wave signal. the bikes ecu only emits 1 volt square wave signal. how do i convert this to a 12volt signal? im thinking that a comparator type circut using a LM393 might work? if this is the correct type of circut i need help with the layout as im not all that clued up on this type of circut. i have a little experience in electronics (kit builder) your help would be most appreciative. thanks allan | |
Have you verified that it is 1v square wave that the ECU, or are you using a data sheet. If you verified it - what did you use, a voltmeter or a scope? dont really know much about transistors, i just experement or copy diagrams off the net and adapt to my needs, but I believe 0.7v will trigger a transistor, so mabey you could get away with a single transistor and mabey a few resistors - im sure someone who knows what there talking about will chime in with something useful.
__________________ There will come a day when PICs will rule the world! | |
| | #3 | |
As per your PM, have redrawn the circuit. I would use the 'A' input, the other half of the LM393 is 'spare' I have shown the RV1 setting for 2V, so adjust for 1V. OK
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
thanks mate for your help thats exactly what i was looking for . hope to share some of my own projects whit you guys once again thanks allan | |
| converting, low, signal, tacho, volt |
| 3.3 Volt to 5.5 Volt Octal TTL line Level Conversion | jbbjshlws | General Electronics Chat | 9 | 8th October 2008 12:03 PM |
| 5 volt chip from 24 volt transformer | Gaston | General Electronics Chat | 20 | 7th February 2008 06:25 AM |
| converting low volt tach signal to 12V | jcw | General Electronics Chat | 18 | 11th January 2008 05:11 AM |
| converting to 12 volt | jace33 | Electronic Projects Design/Ideas/Reviews | 4 | 15th September 2006 03:37 AM |
| How to build a converter from 12 Volt to more than 200 Volt | Christopher Ooi | Electronic Projects Design/Ideas/Reviews | 10 | 27th May 2003 02:34 PM |
