| Hi. A friend told me that you don't need a resistor in series with a flashing LED. Is this true? if so, why? Thanks | |
| There is insufficient information to make a reasonable judgement.......... What voltage flashing led ? what supply volts are being used ? | |
| ermmm, i don't really know. the sort you would use with a 9V battery... | |
| well you definetly need a series resistor.... dont think i know circuits where you don't need a current limmiting resistor..... i am sure you need one. maybe a schematic could do? | |
| The only flashing LED I know of (i.e., running without an external circuit) is a 2.2 volt model with a peak of 4 volts. If you connect this to a 9 volt battery without a limiting resistor, it will flash only once. | |
| Have a look at kingbright. eg. http://www.kingbright-led.com/data/spec/L56BID.pdf They manufacture a range of flashing leds from 3mm to 10mm, no series resistor required with a Vf of up to 13V. Edit: The flasher chip is built into the led. | |
| yes, the flasher is in the led, so the limiting resistors and all you need. and ill say it one more thing...how often don't we use a limiting resistor? | |
| If the duty cycle of the flaher is low, you can also do without the limiting resistor. But this is not at all a good idea. You should always use one to ensure long life of LED.
__________________ "There is no way to peace, peace is the way!" | |
| OK, thanks everyone. I am using a current limiting resistor anyway, and to answer your question bogdanfirst, how often don't we use a limiting resistor? - once!! | |
| when dont you use it? there are little circs that dont require it.....maybe some flashers. | |
| Hi Guys.. Just thought I'd chuck my two penneth worth in.. The flashing LEDs I have (the only ones I can get) are happy with 3.5v to 13v. NO RESISTOR. The internal circuitry contains both the flasher and a current limiter circuit so the resistor is not required up to 13v.
__________________ I need a memory upgrade ... My head is full ! | |
| mechie, they sound alot like my flashing L.E.Ds Mine work with or without resistors, but if you connect them straight to a 9v PP3 battery, they 'pulse', rather than flash! I have changed my circuit completely and am now using a 555 in astable mode, and a small 12v bulb. Thanks for the help everyone grrr_arrghh | |
